[GRASS-dev] wxGUI raster digitizer available
I added raster digitizer in r62792 in trunk. You are welcome to test it and report bugs/enhancements.
It currently allows to draw areas, lines and points and specify width to buffer individual features. We can discuss some changes in gui interface and behavior if you find the current one intuitive. There is still a lot to improve especially in the drawing part (needs some refactoring of the old drawing code).
Features:
  • draw area, line, point
  • specify buffer width for individual features to create for example circles, roads of certain width…
  • specify background map
  • simple undo
  • save button to save results during drawing
  • keeps drawing order in the output raster map
  • change color of drawing
  • doesn’t block gui when exporting raster (which can take some time)
Does not support (yet?):
  • adding labels
  • interactive setting color of raster cells (not planned, there are other tools)
  • vector export/import
Known issues:
  • r.in.poly supports only CELL (I just realized that, this must be changed)
  • various small drawing issues
  • slow when exporting features with buffers (r.grow is slow, probably because it’s a script)
Anna
Hi Anna,
On Tue, Nov 18, 2014 at 5:19 AM, Anna Petrášová <kratochanna@gmail.com> wrote:
what a great job!
If you didn't find it: it is in the "Map Display" windows, then
selector on the right side (2D/3D/Vector digitizer/Raster digitizer).
drawing code).
One general thing I found (also valid for the vector digitizer): I
wonder where to put a message what the mouse buttons mean.
Maybe in the status bar at bottom of the display/digitizer window?
Features:
- draw area, line, point
... works.
- specify buffer width for individual features to create for example
circles, roads of certain width...
... maybe rename from "Width" to "Buffer width"? Otherwise it could be
confused with the drawing line width.
- specify background map
... works (maybe have a button to optionally take computational region
from that map?)
- simple undo
- save button to save results during drawing
here I got an issue somewhere:
Exception in thread Thread-4:
  File "/usr/lib64/python2.7/threading.py", line 811, in
__bootstrap_inner
    self.run()
  File "/home/neteler/software/grass71/dist.x86_64-unknown-
linux-gnu/gui/wxpython/core/gthread.py", line 94, in run
    ret = vars()['callable'](*args, **kwds)
linux-gnu/gui/wxpython/rdigit/controller.py", line 432, in
_exportRaster
    if item.GetPropertyVal('widthValue') and \
linux-gnu/gui/wxpython/mapwin/graphics.py", line 439, in
GetPropertyVal
    raise KeyError(_("Property does not exist: %s") %
(propName))
KeyError: 'Property does not exist: widthValue'
- keeps drawing order in the output raster map
- change color of drawing
- doesn't block gui when exporting raster (which can take some time)
Nice!
- adding labels
- interactive setting color of raster cells (not planned, there are other tools)
- vector export/import
Known issues:
- r.in.poly supports only CELL (I just realized that, this must be changed)
(meanwhile you changed that already, thanks)
- various small drawing issues
- slow when exporting features with buffers (r.grow is slow, probably
because it's a script)
Not sure but r.buffer would be appropriate/faster?
On Wed, Nov 19, 2014 at 3:31 PM, Markus Neteler <neteler@osgeo.org> wrote:
Hi Anna,
wrote:
> Hi all,
what a great job!
Once everything works, I will probably make a short video tutorial.
and
> drawing code).
> Features:
... works.
There is not much space in toolbar..., especially if we in the future add
more items (settings, label editing for example). What about just 'Buffer'?
Currently the width is the width of the buffered line/diameter of the point
(circle), which means 2 x buffer distance, so if we change it to buffer,
then the value should be half of the line width?
from that map?)
Yes possibly, I am not sure about the region in general, if there should be
any special handling.
> - simple undo
__bootstrap_inner
    self.run()
_exportRaster
GetPropertyVal
(propName))
it normally works... Does this happen every time?
Nice!
> - adding labels
other tools)
> Known issues:
changed)
I considered that but the cells grown by r.buffer have different values
than the original ones, so I would have to reclassify it, so I am not sure
if it would be faster in the end.
Thanks for your feedback!
Anna
Hi Anna
This is great, thanks! This is going to be a real time saver.
I am having trouble however running it. I seems to work fine except that I can’t save the edits. To leave the editing session, I have to select no when asked to save the work.
Not sure if the below helps, but in the terminal I get the message: GRASS_INFO_ERROR(30864,1): Raster map <pnv_malawi2_ag2_backupcopy_30725> not found
GRASS_INFO_END(30864,1)
From the command console:
Exception in thread Thread-8:
File “/usr/lib/python2.7/threading.py”, line 810, in
__bootstrap_inner
self.run()
File “/usr/local/grass7/grass-7.1.svn/gui/wxpython/core/gt
hread.py”, line 94, in run
ret = vars()[‘callable’](*args, **kwds)
File “/usr/local/grass7/grass-7.1.svn/gui/wxpython/rdigit/
controller.py”, line 467, in _exportRaster
output=self._editedRaster, overwrite=True, quiet=True)
File “/usr/local/grass7/grass-7.1.svn/etc/python/grass/scr
ipt/core.py”, line 373, in run_command
return handle_errors(returncode, returncode, args,
kwargs)
ipt/core.py”, line 308, in handle_errors
returncode=returncode)
CalledModuleError: Module run None [‘r.patch’, ‘–o’, ‘–q’,
u’input=x47731795,pnv_malawi2_ag2_backupcopy_30725’,
u’output=pnv_malawi2_ag2@vegetation’] ended with error
Process ended with non-zero return code 1. See errors in the
(error) output.
On Wed, Nov 19, 2014 at 11:56 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
grass-dev mailing list
grass-dev@lists.osgeo.org
Hi Anna,
what a great job!
If you didn’t find it: it is in the “Map Display” windows, then
drawing code).
Features:
… works.
… maybe rename from “Width” to “Buffer width”? Otherwise it could be
There is not much space in toolbar…, especially if we in the future add more items (settings, label editing for example). What about just ‘Buffer’? Currently the width is the width of the buffered line/diameter of the point (circle), which means 2 x buffer distance, so if we change it to buffer, then the value should be half of the line width?
… works (maybe have a button to optionally take computational region
from that map?)
Yes possibly, I am not sure about the region in general, if there should be any special handling.
  • simple undo
File “/usr/lib64/python2.7/threading.py”, line 811, in
__bootstrap_inner
self.run()
File “/home/neteler/software/grass71/dist.x86_64-unknown-
linux-gnu/gui/wxpython/core/gthread.py”, line 94, in run
linux-gnu/gui/wxpython/rdigit/controller.py”, line 432, in
exportRaster
if item.GetPropertyVal(‘widthValue’) and
linux-gnu/gui/wxpython/mapwin/graphics.py”, line 439, in
GetPropertyVal
raise KeyError(
(“Property does not exist: %s”) %
(propName))
KeyError: ‘Property does not exist: widthValue’
it normally works… Does this happen every time?
Nice!
  • adding labels
Known issues:
I considered that but the cells grown by r.buffer have different values than the original ones, so I would have to reclassify it, so I am not sure if it would be faster in the end.
Anna
On Thu, Nov 20, 2014 at 4:37 AM, Paulo van Breugel <p.vanbreugel@gmail.com>
wrote:
Hi Anna
can't save the edits. To leave the editing session, I have to select no
not found
  File "/usr/lib/python2.7/threading.py", line 810, in
__bootstrap_inner
    self.run()
  File "/usr/local/grass7/grass-7.1.svn/gui/wxpython/core/gt
  File "/usr/local/grass7/grass-7.1.svn/gui/wxpython/rdigit/
controller.py", line 467, in _exportRaster
  File "/usr/local/grass7/grass-7.1.svn/etc/python/grass/scr
ipt/core.py", line 373, in run_command
kwargs)
ipt/core.py", line 308, in handle_errors
CalledModuleError: Module run None ['r.patch', '--o', '--q',
u'input=x47731795,pnv_malawi2_ag2_backupcopy_30725',
u'output=pnv_malawi2_ag2@vegetation'] ended with error
(error) output.
Strange, could you describe the exact steps?
wrote:
Hi Anna,
wrote:
> Hi all,
what a great job!
to
interface and
to
old
> drawing code).
> Features:
... works.
from that map?)
> - simple undo
__bootstrap_inner
    self.run()
_exportRaster
GetPropertyVal
(propName))
Nice!
> - adding labels
other tools)
> Known issues:
changed)
Anna
While trying to replicate the steps, I found out it worked this time. Difference was that last time I edited a very large map so the process got probably stuck. Sorry for the false alarm. And again, a great new feature!!
On Thu, Nov 20, 2014 at 7:31 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
On Thu, Nov 20, 2014 at 4:37 AM, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Hi Anna
__bootstrap_inner
self.run()
kwargs)
(error) output.
Hi Anna,
what a great job!
drawing code).
Features:
… works.
from that map?)
  • simple undo
__bootstrap_inner
self.run()
exportRaster
GetPropertyVal
raise KeyError(
(propName))
Nice!
  • adding labels
Known issues:
Anna
On Thu, Nov 20, 2014 at 3:03 PM, Paulo van Breugel <p.vanbreugel@gmail.com>
Just let me know if it happens again, it will probably take some time until
we find and fix the bugs.
Hi Anna
I can't save the edits. To leave the editing session, I have to select no
not found
__bootstrap_inner
    self.run()
kwargs)
(error) output.
wrote:
Hi Anna,
wrote:
> Hi all,
what a great job!
width to
interface and
lot to
the old
> drawing code).
> Features:
... works.
'Buffer'? Currently the width is the width of the buffered line/diameter of
from that map?)
> - simple undo
__bootstrap_inner
    self.run()
_exportRaster
GetPropertyVal
(propName))
Nice!
> - adding labels
other tools)
> Known issues:
changed)
Anna
Awesome !! Thank you very much Anna !
Il 18/11/2014 05.19, Anna Petrášová ha scritto:
Features:
  • simple undo
  • adding labels
Known issues:
Anna
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
