On Tue, Dec 18, 2012 at 2:34 PM, Mohammed Rashad
<mohammedrashadkm@gmail.com> wrote:
Hi All,
I had committed the first version wxGUI Raster Digitizer[1]. Adding/removing
Circles is not available for the moment. There is a lot more to do yet. But
It will be great to have some test results/suggestion/feedback.
From your screenshot What I understand is you loaded a raster map but did not created or selected the map to be saved. Output map seems to be empy. I had updated svn for check if map is available. Now wx.rdigit shows error message if no map is selected
Also All your Observations are considered and module is modified accordingly
Please update source and try again.
PS: There is a feature not implemented in it which asks for category id and num for each digitized object created. I will implement it after current testing. Because there are some discussion regarding no need for a digitizer since the same can be acheived from v.digit and v.to.rast
On Thu, Dec 20, 2012 at 4:04 PM, Markus Neteler <neteler@osgeo.org> wrote:
