[GRASS-dev] wxGUI: "Save display to graphic file" and d.out.file options
in wxGUI, the "Save display to graphic file" is yet rather limited
with respect to what gis.m provided (disk symbol). I wonder if
functions from d.out.file could be added, at least to define the
resolution and such. Since d.out.file already generates wxpython code
could it be recycled in the GUI? (d.out.file fails and wants an X monitor).
2009/10/16 Markus Neteler <neteler@osgeo.org>:
is there any reason why d.out.file requires X monitors? It would be
cool to have d.out.file also in GRASS7.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
d.out.file requires a monitor from which to obtain the list of
displayed maps (i.e. d.save). It doesn't have to be an X monitor.
Obviously, the GUI has this information somewhere.
Actually, it has the code as well; see Layer.Render and Map.Render in
render.py.
