[GRASS-dev] wxnviz broken in 6.5 on Linux 64bit
Message:
3D view mode not available
Reason: /lib/libz.so.1.2.3: wrong ELF class: ELFCLASS32
Note that the wxGUI's 3D view mode is currently disabled on
MS Windows (hopefully this will be fixed soon). Please keep
an eye out for updated versions of GRASS. In the meantime
you can use "NVIZ" from the File menu.
Problem is ctypes, the Makefiles have been backported from trunk
without adapting to the build system in 6.5.
in 6.5, lib/python/ctypes/nviz.py imports 34 libs:
# Begin libraries
_libs["grass_nviz"] = load_library("grass_nviz")
_libs["grass_bitmap"] = load_library("grass_bitmap")
_libs["grass_linkm"] = load_library("grass_linkm")
_libs["grass_g3d"] = load_library("grass_g3d")
_libs["grass_gis"] = load_library("grass_gis")
_libs["grass_datetime"] = load_library("grass_datetime")
_libs["z"] = load_library("z")
_libs["grass_vect"] = load_library("grass_vect")
_libs["grass_dbmibase"] = load_library("grass_dbmibase")
_libs["grass_dbmiclient"] = load_library("grass_dbmiclient")
_libs["grass_dgl"] = load_library("grass_dgl")
_libs["grass_dig2"] = load_library("grass_dig2")
_libs["grass_rtree"] = load_library("grass_rtree")
# 34 libraries
# End libraries
in 7.0, lib/python/ctypes/nviz.py imports only one lib:
# Begin libraries
_libs["grass_nviz.7.0.svn"] = load_library("grass_nviz.7.0.svn")
# 1 libraries
# End libraries
The same applies to all other files generated in lib/python/ctypes
The difference is caused by $(NVIZLIB) != $(NVIZLIB) between 6.5 and
7.0, same for all others in lib/python/ctypes/Makefile
In 6.5 it should read something like
date_LIBS = -l$(DATETIME_LIBNAME)
etc.
instead of
date_LIBS = $(DATETIMELIB)
More modifications might be necessary.
Markus M
2010/8/30 Markus Metz <markus.metz.giswork@googlemail.com>:
right, see http://trac.osgeo.org/grass/ticket/1125#comment:43
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
On Mon, Aug 30, 2010 at 1:16 PM, Martin Landa <landa.martin@gmail.com> wrote:
In the long run it might be better to backport the new Makefiles system
from GRASS 7. It would also help for g.extension and the like.
Makefiles system from GRASS 7.
..or stop making invasive changes to 6.x and focus on
grass7 for new development instead..
2c,
Hamish
(fyi I hope to deal with g.extention C builds from official
packaged versions of 6.4 from debian+ubuntu soon, ensuring
makefile variables in -dev packages point to installed
includes/, not original build dir)
2010/8/30 Hamish <hamish_b@yahoo.com>:
ctypes backport is quite important for wxGUI also in GRASS 6.5.
Martin
2010/8/30 Markus Neteler <neteler@osgeo.org>:
I would vote for minimalistic approach, ctypes will be probably
backported to 6.4.x, any heavy changes are complicated in this regard.
Martin
