[GRASS-dev] wxpython 3 and errors in grass
I've recently started to see errors when trying to run gui tools such as the interactive color definition or when I try to add a legend to the map composer, and the windows do not open. The traceback is below.
I imagine that this is linked to the fact that I have now wx 3 installed next to wx 2. But what is the solution ?
Moritz
   File
"/data/home/mlennert/SRC/GRASS/grass64_release/dist.x86_64
-unknown-linux-gnu/etc/wxpython/lmgr/frame.py", line 1182,
in RulesCmd
ctable = RasterColorTable(self)
   File
-unknown-linux-gnu/etc/wxpython/modules/colorrules.py", line
752, in __init__
title = _('Create new color table for raster map'),
**kwargs)
   File
334, in __init__
self._doLayout()
   File
780, in _doLayout
bodySizer = self._createBody(parent = self.panel)
   File
469, in _createBody
bodySizer.AddGrowableCol(2)
   File "/usr/lib/python2.7/dist-
packages/wx-3.0-gtk2/wx/_core.py", line 15364, in
AddGrowableCol
return _core_.FlexGridSizer_AddGrowableCol(*args, **kwargs)
wx._core
PyAssertionError
C++ assertion "!m_cols || idx < (size_t)m_cols" failed at
../src/common/sizer.cpp(1980) in AddGrowableCol(): invalid
column index
On Thu, Oct 30, 2014 at 1:57 PM, Moritz Lennert <
mlennert@club.worldonline.be> wrote:
It is totally fine to use wxPython 3 on Linux, so the solution is to fix
the bugs. We actually need someone testing it with the newer version. Most
bugs are quite easy to fix, so please report them to me directly offlist
and I will let you know if I can fix it immediately or if you should create
a ticket in case of more complicated things.
wxPython on Mac is a different story, it's much more problematic, because
the 32-bit version is difficult compile with and the 64-bit version is
buggy. No idea about Windows.
I fixed the colorrules.py, could you send me some more info about the other
problem?
Anna
Moritz
  File
in RulesCmd
  File
752, in __init__
**kwargs)
  File
334, in __init__
self._doLayout()
  File
780, in _doLayout
  File
469, in _createBody
AddGrowableCol
wx._core
PyAssertionError
column index
grass-dev mailing list
grass-dev@lists.osgeo.org
On Thu, Oct 30, 2014 at 9:34 PM, Anna Petrášová <kratochanna@gmail.com>
other problem?
I fixed cartographic composer too, but let me know if you still have some
problems.
Anna
Moritz
  File
in RulesCmd
  File
752, in __init__
**kwargs)
  File
334, in __init__
self._doLayout()
  File
780, in _doLayout
  File
469, in _createBody
AddGrowableCol
wx._core
PyAssertionError
column index
