For both G70 and trunk, /osgeo/grass7_trunk/gui/wxpython/iclass fails to compile:
ImportError: NumPy not found.
This module requires the NumPy module, which could not be
imported. It probably is not installed (it's not part of the
standard Python distribution). See the Numeric Python site
(http://numpy.scipy.org) for information on downloading source or
binaries.
On Sun, Nov 9, 2014 at 6:02 PM, Nikos Alexandris
compile:
binaries.
I can compile GRASS 7 successfully on Fedora 20
(numpy-1.8.2-1.fc20.x86_64) and Scientific Linux 6.4
(numpy-1.6.1-2.el6.x86_64).
What is the relationship of numpy's oldnumeric and GRASS 7? Any error messages?
compile:
binaries.
Yes, the above. Ehh.. maybe not related to G7 directrly? Complete msg:
File "/osgeo/grass7_trunk/dist.x86_64-unknown-linux-gnu/scripts/g.gui.iclass", line 62, in <module>
from iclass.frame import IClassMapFrame
File "/osgeo/grass7_trunk/dist.x86_64-unknown-linux-gnu/gui/wxpython/iclass/frame.py", line 61, in <module>
from iclass.plots import PlotPanel
File "/osgeo/grass7_trunk/dist.x86_64-unknown-linux-gnu/gui/wxpython/iclass/plots.py", line 19, in <module>
import wx.lib.plot as plot
File "/usr/lib64/python2.7/site-packages/wx-3.0-gtk2/wx/lib/plot.py", line 126, in <module>
raise ImportError, "NumPy not found.\n" + msg
binaries.
It's an issue with the wx.lib.plot module in wxPython. It wants a
"numeric" module, for which it tries:
try:
import numpy.oldnumeric as _Numeric
except:
try:
import numarray as _Numeric #if numarray is used it is renamed Numeric
except:
try:
import Numeric as _Numeric
except:
msg= """
This module requires the Numeric/numarray or NumPy module,
which could not be imported. It probably is not installed
(it's not part of the standard Python distribution). See the
Numeric Python site (http://numpy.scipy.org) for information on
downloading source or binaries."""
raise ImportError, "Numeric,numarray or NumPy not found. \n" + msg
Essentially, it tries three options from newest to oldest. But even
the newest is old enough that it's commonly unavailable (the
oldnumeric module was removed from NumPy in version 1.9).
Code should now be using the numpy interface. Apparently wxPython has
only recently done this:
The problem for my box is not the version of wxwidgets. I have both ver. 2.8 and 3.0 and can easily switch between them when compiling a packages (Gentoo/Funtoo's eselect tool). Removing numpy 1.9.x and installing 1.8.SomeThing, results in an error-free compilation.
If I can translate this correctly, anything that uses "oldnumeric", will be a problem. NumPy 1.9 dropped support for it. In this case, g.gui.iclass.py uses something that uses (something that uses?) oldnumeric. This will stop working at some point.
try:
except:
try:
except:
try:
except:
msg= """
