I just updated from the svn and built GRASS 7. Initially, it gave an error for the wxpython gui. But when I switched to the gui dirctory and ran make, it all compiled fine. So it seems that something in the make file is not working correctly for the gui.
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 SHESC), 480-727-0709 (CSDC)
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
Same here on Vista. The wxpython dir is missing from the build dir.
osgeo4w\bin\python.exe: can't open file
'c:/programs/gis/osgeo4w/apps/grass/grass-7.0.svn/etc/wxpython/gis_set.py':
[Errno 2] No such file or directory
Something to do with r41557?
Michael
C. Michael Barton
grass-dev mailing list
grass-dev@lists.osgeo.org
Needs an edit to lib/init/functions.sh line 263.
@@ -260,7 +260,7 @@
# ok
if [ "$?" = 0 ] ; then
# Set the wxpython base directory
- WXPYTHONGRASSBASE="$ETC/wxpython"
+ WXPYTHONGRASSBASE="$ETC/gui/wxpython"
else
# Python was not found - switch to text interface mode
cat <<-EOF
I think it was missed when martinl made r41557.
-Colin
On 31 March 2010 23:46, Colin (Nielsen) Wren <colin.nielsen@gmail.com> wrote:
Michael
C. Michael Barton
What error, exactly?
The wxpython dir was moved to gui/wxpython (r41557) by martinl. If
you're getting the same error as I was then then this should fix it.
The error was:
Starting GRASS ...
WARNING: Attention!
WARNING: Locking is not supported on Windows!
c:\programs\gis\osgeo4w\bin\python.exe: can't open file
'c:/programs/gis/osgeo4w/apps/grass/grass-7.0.svn/etc/wxpython/wxgui.py':
I posted before with a one line fix, but two lines need changing I think:
Index: functions.sh
--- functions.sh (revision 41651)
+++ functions.sh (working copy)
@@ -260,7 +260,7 @@
# ok
else
cat <<-EOF
@@ -593,7 +593,7 @@
case "$GRASS_GUI" in
wxpython)
- "$GRASS_PYTHON" "$GISBASE/etc/wxpython/wxgui.py" &
+ "$GRASS_PYTHON" "$WXPYTHONGRASSBASE/wxgui.py" &
# Ignore others
-Colin
Index: functions.sh
[snip]
Okay; committed in r41675.
