[GRASS-dev] wxpython not working in GRASS 7 Mac OSX
I just compiled from the most recent svn version of trunk. When I go to display something in the 3D mode (wxnviz), I get the following error. The map does not display and the 3D control panel does not launch.
GRASS 7.0.svn (Spearfish60_test):~ > Traceback (most recent call last):
  File "/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.8.0/etc/gui/wxpython/gui_modules/toolbars.py", line 325, in OnSelectTool
    self.parent.AddToolbar("nviz")
  File "/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.8.0/etc/gui/wxpython/gui_modules/mapdisp.py", line 473, in AddToolbar
    self._addToolbarNviz()
  File "/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.8.0/etc/gui/wxpython/gui_modules/mapdisp.py", line 386, in _addToolbarNviz
    self._layerManager.goutput.WriteCmdLog(_("Starting 3D view mode..."))
  File "/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.8.0/etc/gui/wxpython/gui_modules/goutput.py", line 417, in WriteCmdLog
    self.WriteLog(line, style=self.cmd_output.StyleCommand, switchPage = True)
  File "/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.8.0/etc/gui/wxpython/gui_modules/goutput.py", line 388, in WriteLog
    self._notebook.SetSelectionByName('output')
  File "/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.8.0/etc/gui/wxpython/gui_modules/menuform.py", line 2071, in SetSelectionByName
    self.SetSelection(self.GetPageIndexByName(page))
  File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/python/wx/lib/agw/flatnotebook.py", line 4174, in SetSelection
    self._mainSizer.Insert(0, self._windows[page], 1, wx.EXPAND)
  File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/python/wx/_core.py", line 12707, in Insert
    return _core_.Sizer_Insert(*args, **kwargs)
wx._core.PyAssertionError: C++ assertion "!sizer || m_containingSizer != sizer" failed at /BUILD/wxPython-src-2.8.12.0/src/common/wincmn.cpp(1884) in SetContainingSizer(): Adding a window to the same sizer twice?
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
Michael,
I just updated GRASS7 and wxpython and wxnviz works OK for me.
The only error that I get is this (when quitting wxpython)
pythonw2.6(41179,0xa05a8540) malloc: *** error for object 0x1d43edf0: pointer being freed was not allocated
*** set a breakpoint in malloc_error_break to debug
I am wondering what others compiling on Mac get in terms of running wxgui
Helena
Michael
C. Michael Barton
I did a make distclean before a svn up.
I installed the latest stable wxPython (2.8.12), and have Mac OSX system Python 2.6.1. My config string is the one I've been using successfully for awhile and which works fine for 6.5 and 6.4.
The only difference is that I made GRASS 7 with make GDAL_DYNAMIC= William suggested this sometime back because of problems with v.external and r.external.
Michael
C. Michael Barton
On Jun 30, 2011, at 7:50 PM, Helena Mitasova wrote:
Michael,
Helena
Michael
C. Michael Barton
Hello Helena and Michael,
I don't get this error and it's hard to tell where the problem is.
According to the traceback the problem occurs when switching to command output page. Do you have this problem in any other cases (eg. query raster map with Map layer tab selected)?
Anna
> File
> File
> File
> File
> File
> File
> File
> File
12707, in Insert
> Michael
> C. Michael Barton
grass-dev mailing list
grass-dev@lists.osgeo.org
I just put GRASS 7 onto my office desktop iMac. This is the version that I compiled yesterday. the iMac is not a development machine, but has the same new frameworks from William Kyngesburye's site. I get the same error when I try to go to 3D mode. It won't open the 3D control panel. Could it possibly be the new frameworks??? Cairo or FreeType?
Michael
473, in AddToolbar
398, in _addToolbarNviz
self._layerManager.AddNviz()
  File "/Applications/Grass/GRASS-7.0.app/Contents/MacOS/etc
/gui/wxpython/wxgui.py", line 279, in AddNviz
display = self.curr_page.maptree.GetMapDisplay())
darwin10.8.0/etc/gui/wxpython/gui_modules/nviz_tools.py",
line 140, in __init__
self.AddPage(page = self._createDataPage(),
line 382, in _createDataPage
style = fpb.FPB_DEFAULT_STYLE, extraStyle =
fpb.FPB_SINGLE_FOLD)
AttributeError
'module' object has no attribute 'FPB_DEFAULT_STYLE'
Michael
______________________________
C. Michael Barton
Tempe, AZ 85287-2402
USA
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
Anna
File
File
File
File
File
File
File
File
12707, in Insert
Michael
C. Michael Barton
grass-dev Info Page
AttributeError
already fixed in r46896.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Thanks. I'll try to compile it again this weekend.
Michael
C. Michael Barton
USA
AttributeError
Martin
Martin Landa <landa.martin gmail.com> * Studijní program Geodézie a kartografie – GeoWikiCZ
