[GRASS-dev] wxvdigit
Why don't you just call the C API from C++?
The VEdit C library has some convenient functions for building
a digitizer application.
Ben
----- Original Message -----
What I want is a vector digitizer using GRASS. I read programmers
manual and saw the code to create vector files. I want to edit/add
data(points/lines or atleast points) on the new created vector map
like the wx digitizer. I am using C++ for developing my application
not python or wx.python.
I knew how to replace python code with my C++. But wx digitzer uses a
swig interface and calls a .so file _grass6_wxvdigit.so located in
/usr/local/grass-6.5.svn/etc/wxpython/vdigit.
Can I use the .so file said above in my code. As I am developing with
C++ I can directly link the
_grass6_wxvdigit.so file. I am asking that Can I link the .so file
with my C++ code . normally its possible and easy. But the .so files
is swig generated(I maybe wrong)
Is Information said above is enough or If you want more please tell me
which part need more explanation. I am ready to provide you.
On Wed, Sep 29, 2010 at 5:49 PM, Benjamin Ducke <
benjamin.ducke@oxfordarch.co.uk > wrote:
How about you explain to us what you want to achieve with your
program? If people here understand what you are trying to do,
they can give you more useful advise.
If all you want is to create some vector objects, you can use
the GRASS C API from within your C++ code. There is a programmer's
manual which you can consult:
http://grass.fbk.eu/devel/index.php#prog
and of course, you have the source code of all GRASS GIS modules,
so you can try to find one that does something similar to what
you want and learn from that.
Ben
> How can I communicate with wx digitizer ( i mean using the
> wxdigit.so file) using a c++ program.
> All I need is create an map with one point from a c++ program which
> is linked to _grass6_wxvdigit.so located in
> How to access the functions of the library using a C++ program run
> from grass shell with all variables set. My program renders a map
> when run from grass shell. Now I want to add
> digitzer;
> -- Rashad
> _______________________________________________ grass-dev mailing
> list grass-dev@lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
------ Files attached to this email may be in ISO 26300 format (OASIS
Open Document Format). If you have difficulty opening them, please
visit http://iso26300.info for more information.
-- Rashad
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
