On Jan 24, 2010, at 10:55 PM, Helena Mitasova wrote:
Just a follow up on the Mac installation issues:
as I mentioned several users reported problems switching from tcltk GUI to wxGUI:
after running g.gui in all possible ways they kept getting an error message.
It turns out that the problem was missing FFTW3 library (on Leopard only?)
- after installing the correct version of FFTW3 everything runs fine.
Correct. It sounded like a rc6 was imminent, and it may still be, lots of activity in the wingrass build, so I've been holding off on a rebuild of the older Leopard package to fix this.
Another most common problem was people forgetting to install Active Tcl
and then complaining that nviz keeps crashing. Or they thought that Active
Tcl is needed only for Tcltk GUI and when they are running wxpython GUI it is not needed.
I could look at the ActiveState license to see if I can bundle it in GRASS (I used to do that for the X11 TclTk). It's mainly so I have 1 less thing to compile
Everything is written on the web site so there isn't really a problem as long as
the users read carefully the instructions (what nobody does these days).
As more OS versions and GRASS releases have been added to the web page
people simply overlook important issues.
So William and others on Mac, I am wondering whether it would help for future
to have the instructions for Snow Leopard written in a simpler way something like this
For Snow Leopard install:
- Unix Compatibility Frameworks: SQLite3, FreeType, UnixImageIO, PROJ, GEOS, and GDAL
Even simpler now, I just haven't updated the page yet: FreeType and GDAL Complete.
- ActiveTcl 8.5 (not 8.6) from ActiveState
- GRASS.app 64
- sample data set from here: link
(I am not sure I have it right, but I assume that Python, wxPython and FFTW3
does not have to be installed separately)
For older Mac OS X versions I would keep it as is.
I am not sure that this is the best solution, others may have better ideas,
I hope it will change soon (new version) so this won't be necessary. If it looks like rc6 is still a ways off, I can rebuild.
Thanks for the comments, it's spurred my brain a little to ponder possibilities.
thank you,
Helena
grass-dev mailing list
grass-dev@lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
