[GRASS-dev] ZSTD compressor not compiled by default if available
Dears,
do I understand it wrong that, if available in a system, the ZSTD
compressor _should_ be compiled by default? Or does the choice for
"default" concern only the `r.compress` module?
In trunk:
./configure --help |grep zstd
  --with-zstd             support Zstandard functionality (default: no)
  --with-zstd-includes=DIRS
  --with-zstd-libs=DIRS   ZSTD library files are in DIRS
Thank you, Nikos
Hi Nikos,
On Mon, Feb 4, 2019 at 2:18 PM Nikos Alexandris <nik@nikosalexandris.net> wrote:
Dears,
I don't think so as it says "default: no" (see below).
In trunk:
On my systems, I always define
configure ... \
   --with-zstd \
