I am trying to set up a grass users group on our workstation so that
multiple users can access GRASS. I have the permissions set for the grass
data directory so that the group "grass" has read,write,exe access.
However, when a user who is part of this group starts up grass and
specifies the mapset/location, this message shows up:Sorry, no access to <<maps>>.
Mapsets in location <wachob>
PERMANENT mapsnote: you do not have access to any of these mapsets
----------------------If anyone has some idea what is going on here, info would be appreciated!
The setup in the user's .cshrc is this:
setenv GISBASE /tools/grass/grass4.0/sun4
alias grass4 \$GISBASE/etc/GIS.shand the .grassrc is this:
q
MAPSET: maps
GISDBASE: /sea/grassdata
(except for the q - sorry, typo)Please mail any responses directly to me: meh@zoosun1.uwyo.edu
as I am not subsribed to this list.Thanks in advance!
Margo Herdendorf
We keep the following script in /usr/local/bin/grass4. If a new user is
identified, then the perl script new_user.p is executed to attach shared
databases through soft links.
grass4:
# Bourne script for entering grass4.1 using executables on heart
BASENAME=`basename $0`
GIS="/files/data/heart/data1/grassdir/grass4.1"
# DIR="/files/data/hydro/data2/grass4.1"
DIR=${GIS}/bin
if [ ! -d $DIR ]
then
echo "One moment . . . I need to mount disks attached to heart"
nfsmount heart
fi
PATH=$DIR:$PATH
export GIS PATH
# export GIS GISDBASE PATH
# for new users, create the initial GISDBASE
if [ ! -s "$HOME/.grassrc4" ]
then
echo "One moment . . . establishing GRASS database linkages for you"
$GIS/../home/new_user.p
fi
trap 'exit' 0 1 2 3 15
if [ $BASENAME = "grass4" ]
then
grass4.1.new
else
home=`cd;pwd`
# if xgrass databases not specified, use the database from .grassrc4
if [ ! -f "$home/.xgrass/databases" ]
then
if [ -f "$home/.grassrc4" ]
then
if [ ! -d "$home/.xgrass" ]
then
mkdir $home/.xgrass
fi
grep GISDBASE $home/.grassrc4 | sed -e 's:^.* /:/:' \
fi
fi
xgrass4.1.new $*
fi
new_user.p:
#!/usr/local/bin/perl
# written to attach ERL-C GRASS Database to new GRASS user's database
#require "getopts.pl";
#&Getopts ('w');
$home = $ENV{'HOME'};
$dir = $opt_w ? "/dsk/heart2" : "/files/data/heart/data1";
#kludge
if (! -d $dir) {
$dir = "/dsk/heart2";
@locations = ("us.albers", "us.latlong", "world.latlong");
if (! -d "$home/grass_mapsets") {
mkdir ("$home/grass_mapsets", 0755);
chdir ("$home/grass_mapsets");
foreach $i (@locations) {
if (! -d $i) {
mkdir ($i, 0755);
chdir ($i);
open (FILES, "ls $dir/grassdir/grass.data/$i |");
@list = <FILES>;
foreach $mapset (@list) {
chop $mapset;
next if $mapset =~ /^[a-z]/;
next if $mapset =~ /README/;
next if -d $mapset || -l $mapset;
if ($mapset eq "PERMANENT") {
system ("cp -r $dir/grassdir/grass.data/$i/$mapset $mapset");
else {
system ("ln -s $dir/grassdir/grass.data/$i/$mapset $mapset");
# also connect spearfish data
if (! -d "spearfish") {
mkdir ("spearfish", 0755);
chdir ("spearfish");
unless (-d "PERMANENT" || -l "PERMANENT") {
mkdir ("PERMANENT", 0755);
chdir ("PERMANENT");
foreach $file ("DEFAULT_WIND", "MYNAME", "SEARCH_PATH", "WIND") {
system "cp $dir/grassdir/home/data/spearfish/PERMANENT/$file $file";
chdir ("$home/grass_mapsets/spearfish");
# (-d "spearfish" || -l "spearfish") ? print "yes\n" : print "no\n";
unless (-d "spearfish" || -l "spearfish") {
system "ln -s $dir/grassdir/home/data/spearfish/PERMANENT spearfish";
# write out a .grassrc4 file
open (GRASS, "> $home/.grassrc4");
print GRASS "GISDBASE: $home/grass_mapsets\n";
print GRASS "LOCATION_NAME: us.albers\n";
print GRASS "MAPSET: PERMANENT\n";
