grass: gtopo30 extraction
I'm wondering whether any readers have read a downloadable DEM file,
e.g. e060n40.tar.gz, into grass 5 on a linux machine. The byte order
needs to be reversed, or at least the docs indicate this. If this is
done will m.dem.extract then work? Does the header need to be
reincorporated somehow after untarring the distributed tile file?
Finally, has someone already written a program to do this for the
gtopo30 data?
Yes. Please use the r.in.bin module.
Details are described at:
http://www.geog.uni-hannover.de/grass/admin/gtopo30_import.html
