Malcolm Williamson (malcolm@cast.uark.edu) writes on 4 April 1995:
Darrell McCauley writes:
TeX). So, the product of this rambling is v.out.mif, an awk
script to convert dig_ascii to Maker Interchange Format.ftp://moon.cecer.army.mil/grass/incoming/v.to.mif
If someone writes something for raster data, we could probably
piece together a MIF driver for p.map pretty easily.
FWIW, the following work nicely:
r.out.ppm i=landuse o=- | ppmtopict > /tmp/landuse.pict
/usr/frame/bin/picttomif /tmp/landuse.pict landuse.mif
Although this is probably a pretty fair approach for smaller, low resolution
maps, I have a feeling that FrameMaker might not be happy if it had to deal
with very large raster images. I've toyed with the idea of writing a crude
probably true. I just tried a ~2000 x ~2000 image and Frame would not
show me colors (just a gray box).
point-and-click front end for ps.map, but haven't found the time :(. By the wa
y
we have been producing some really nice (if I must say so myself!) hardcopy wi
th
ps.map, using some extra little tricks, like:
With a little help, ps.map can be a good program.
I didn't mean to dis ps.map (hope it wasn't read that way).
However, for labelling road maps, a pointy-clicky approach
is a lot easier.
Darrell
James Darrell McCauley, PhD http://soils.ecn.purdue.edu/~mccauley/
Dept of Agricultural Engineering mccauley@ecn.purdue.edu
Purdue University tel: 317.494.1198 fax: 317.496.1115
