GRASS>How to undelete vector lines?
when deleting vectors in v.digit, they are just marked as deleted
(following the v.clean manual entry). v.clean would throw them
away later. But if I decide that I need them back, how to *undelete*
the vector lines? I could not find such an entry in v.digit etc.
Thank you
  Markus Neteler
Markus,
  To undelete lines (or areas) that have been deleted but NOT
v.clean(ed), do the following:
cd $LOCATION/dig_att
vi TheVectorFile.InQuestion
(replace all of the lower case characters (either a's or l's) along
the left margin with the UPPER case equivalent... (eg. A or L).. The
global replace option in VI works great for this...
If memory serves me thats all you need to do..... :wink:
Have a good day,
brian culpepper
CAST
On Fri, 22 Jan 1999, Markus Neteler wrote:
Thank you
  Markus Neteler
R. Brian Culpepper GIS Specialist
Center for Advanced Spatial Technologies (fax) 501 575-5218
Rm. 12 Ozark Hall 501 575-6159
University of Arkansas brian@cast.uark.edu
Fayetteville, AR 72701 Home Page: http://www.cast.uark.edu
This takes care of _half_ the problem, the attributes. To recover the
actual geometry, you must run v.out.ascii to produce an ASCII version of
the file. Edit the file the same way that Brian notes below, i.e., change
lower case "a" and "l" to upper case. Use v.in.ascii to re-import the
file. Run v.support when you are finished. Note that this restores _all_
deleted features.
  -Malcolm
On Fri, 22 Jan 1999, Brian Culpepper wrote:
Markus,
Have a good day,
brian culpepper
CAST
> Hi all,
> Thank you
> Markus Neteler
