GRASS import of ARC/INFO .e00 released
the new module m.in.e00 is available now, many thanks to Michel Wurtz!
m.in.e00 allows the import of ESRI's .e00 files into GRASS vector
format.
http://www.geog.uni-hannover.de/grass/projects/m.in.e00/
- source code
- Linux binaries
are available.
Best wishes
Markus Neteler
You may also visit the
    "GRASS module development page"
http://www.geog.uni-hannover.de/grass/main_projects.html
Dear Grass Users
I need help in using v.in.dxf3d commands. I have been trying to convert contour
lines in dxf format to grass format. The problem is that when I used the
v.in.dxf3d command, Z values or elevation data was not transfered to Grass
format. What I did was first run v.in.dxf to convert dxf files to grass format. Then I
run v.in.dxf3d to bring in the Z values but this didn't work.
Hopefully, anyone can point to me ho to use v.in.dxf3d command properly.
BTW, has anyone compiles m.in.e00 on solaris 2.6, I would like to have the
binaries.
Thanks again for any help.
Kamarul
Dept. of Civil Engr
UTM
07-5576160 ext 3026
