GRASS Maps to PC WordPerfect
I just figured out how to get GRASS output
into PC based WordPerfect.
The Hoops -
Hoop 1: Produce a map using p.map.new or any other
         GRASS mapping tool which can be previewed.
Hoop 2: Use Snapshot to capture this map from your
         screen.
Hoop 3: Use xv to edit the image (if needed). I
         was saving color maps as black/white in xv.
Hoop 4: Bring into XWP via Graphics.
Hoop 5: Again, if needed, the image can be edited
         here.
Hoop 6: Save as ... ASCII TEXT (PC EXTENDED) -
         This file can then be used in a document
         produced on a PC.
For the times when GRASS is being used as the GIS
and PC users are writing the text.
Bob Feeney
USACERL-TAS
----- End Included Message -----
