Has anyone successfully run GRASS monitors on 24 bit display ?
I tried to hack the code for XDRIVER but still failed. Currently
GRASS monitors don't run on anything but 8-bit display.
Thanks for any help or comments.
Hsuan-Chih Lu
Department of Urban Planning
University of Illinois at Urbana-Champaign
Hsuan-Chih Lu
Are you attempting to get the grass monitor to user 24-bit color, or do
you need to get your 24-bit monitor to display 8-bit graphics? I haven't
looked at the grass monitor code much, but if you need to do the latter, you
might need to change the program's visual, if the program doesn't do this
already.
Randy Hills, National Operational Hydrologic Remote Sensing Center (NOHRSC)
National Weather Service
Minneapolis, MN
