Grass on CD from Yong Minds
These are the problems we have after Installing Young Minds' GRASS4.0 CD.
(IBM RISC System 6000 320H, AIX 3.2.1, 32 Mb RAM & 64 Mb swap space)
DISPLAY FUNCTIONS:
1) * d.zoom? - If the graphics window is resized using the mouse the
                      image currently displayed is kept. However, if I try to
                      zoom in on an image the graphics window is killed and
                      I get the following error:
             "X Error of failed request: BadMatch (invalid parameter attributes)
              Major opcode of failed request: 73 (X_GetImage)
              Minor opcode of failed request: 0
              Resource id in failed request: 0x600003
              Serial number of failed request: 10606
              Current serial number in output stream: 10606
              ERROR eof from graphics driver."
IMAGE PROCESSING:
2) * i.pca - Every time I run this I get a WARNING: Too many
                      iterations in Jacobi routine, output may be
                      invalid. The eigen values of the transformation
                      matrix above the diagonal are n*e+01 to n*e-01
                      generally. The WARNING message suggests that if
                      these values are not close to zero the Jacobi
                      analysis has failed possibly invalidating the o/p.
                    - If a large region of the image (e.g. 1/4 SPOT scene)
                      is selected for principle components analysis i.pca
                      crashes out of the program with a G_malloc: out of memory
                      before I even get to the warning about the PCA matrix.
3) * i.rectify - Trying to run this program -choosing the analysis option
                      produces a G_malloc error.
VECTOR DATA CAPTURE AND PROCESSING:
4) * v.support - When I patch together two vector maps created by
                      heads-up digitizing and try to create the required
                      dig_plus file by running v.support I get the following
                      error upon trying to display the output (from v.support):
                      Out of Memory.
                      I can display the two vector files prior to and post
                      to v.patch with no problems. The problem starts after
                      I build their topology using v.support.
5) * v.to.rast - Will not execute unless v.support has been run first on the
                      vector file. Tried conversion of vector no v.support, vector
                      patched files with no v.support - both failed either with
                      out-of-memory errors or with prompt to run v.support first.
