This is just a note anticipating those who may have trouble
running grass on a 24 bit Data general Aviion. This machine has
many visuals and the GRASS XDRIVER currently assumes that the
default visual is a PseudoColor Visual. (You can find out which
visuals your server supports and which is the default with the
command xdpyinfo). If the default visual is not a PseudoColor
visual with 256 colorcells, you need to run the X server with:
-cc 3
added to the command line. If you are running xdm (which I think
is the common way these machines are used) one of the things xdm
does, apart from the login interface, is to start X. It looks at
the file:
/var/X11/xdm/Xservers
which contains the information needed for xdm to start the X
server and pass options to it. If your entry for :0 does NOT have
-cc 3 on this line, add it. For example, if it looks like:
:0 local /usr/bin/X11/X :0 bc
add -cc 3:
:0 local /usr/bin/X11/X :0 bc -cc 3
You will need to be the user root to do this. To get the server
restarted, logout (so the xdm login window reappears) and click
on restart. This will restart the X server with the -cc 3 option.
The XDRIVER for GRASS should work now.
