GRASS Printers
There will be a new utility in 4.1 called ps.map similar to p.map
but which creates a color postscript file that can be sent to any
color postscript printer.
|However.... I knew a Tek Phaser and the 4697 is no Phaser..
|political joke.... but is is worth considering. The thermal wax
|makes great images but they do flake off. There is a new Tek
|that uses dye sublimation (sp) and the samples I've seen are
|incredible. Expendables for both are ca $0.50-0.75 depending on who
|you talk to. We are seriously looking at both. They are Postscript
|(level 2) and the only way I know to get GRASS output to them is
|via p.ppm. There are regular rumors of a PS GRASS driver but ???
Michael
