grass prompt
Francois Delclaux <francois.delclaux@mpl.orstom.fr> writes:
I'm working with several mapsets in the same database, and sometimes
I don't know what is the current mapset and the current search path.
It's quite easy to set the prompt to the current mapset in the GIS.sh
start up file, but after
the prompt is always the same, even if I work in another mapset.
A solution is to write a script wich modifies the prompt according to
the
current mapset and search path and to execute this script manualy.
But I would like to have an automaticaly updated prompt .
Well I am looking at the Grass prompt, and it displays the current _mapset_,
but not the current _search path_. The quickest way of displaying the search
path is to define an alias for a new 'g.mapsets' command, and put it somewhere
appropriate like $GISRC.cshrc, eg:
set prompt = "GRASS 4.2 > "
alias g.maps '$GISBASE/bin/g.mapsets mapset=\!*; echo "Mapset <${MAPSET}> in Location <${LOCATION_NAME}> with Search-Path <\!*>"'
Usage: g.maps mapset1[,mapset2...]
The slower solution is of course to hack the g.mapsets code.
