Grass raster to ArcInfo grid?
The problem is in the colr tables. Arc only knows about
3.x color structures not 4.x. Two solutions:
There is an environment varible called something GRASS_COLORS..
or something. If that is set then when a map is created it is created with
a 3.x not a 4.x colr table and ARC is happy. The actual varible
name should be known to someone on the list or is in the GRASSu/p
archives somewhere.
OR
you can blow away the colr file (save it under another name)
and then run the ARC command. You will then have to create a color
table in ARC.
What I don't get is why ESRI didn't update the ARC code in
7.0 The GRASS colr specs have been published for a couple of years.
Oh well, I guess I *do* know.
The ArcInfo command "imagegrid" has the option to import GRASS raster formats.
However, this appears to be only Grass3.1 format. We were working with a
ArcInfo 7.1. Is there any way to convert from Grass 4.1 to 3.1 formats? Is there
another way to get Grass raster formats into Arc Grid?
Bruce Wylie
W. Fredrick Limp, Director and Professor FAX: (501) 575-3846
CAST, Center for Advanced Spatial Technologies TEL: (501) 575-6159
12 Ozark Hall, University of Arkansas
Fayetteville AR 72701 fred@cast.uark.edu
