GRASS .SIT to .VEC conversion
Kevin Kingdon writes:
I am looking for a routine that will convert GRASS .SIT files into GRASS
vector format. This routine is not included in our current version of
grass (update 4 I believe). I also checked the moon site and could not
find it there. If anyone knows where I can find this routine (preferably
compiled) I would greatly appreciate it.
The program you want is called s.to.vect and is available in GRASS 4.1
under src.contrib/SCS/sites. I suppose you haven't compiled all the
contributed programs, so you just run gmake4.1 on it (and don't forget to
run MAKELINKS after that).
Good luck,
Philip Verhagen
      S t i c h t i n g R A A P
    Regionaal Archeologisch Archiverings Projekt
adress: Plantage Muidergracht 14
          1018 TV Amsterdam
           THE NETHERLANDS
phone: (31) 20 525 5835
fax: (31) 20 525 5834
e-mail: motte@xs4all.nl
