grass & solaris2.5
Hi grassusers,
I've installed a solaris version on my sunsparc4 (grass4.1u5sol2.5 from
moon /outgoing).
When I digit the well knows d.command,
GRASS-GRID>d.mon start=x0
grass responds:
Usage:
      d.mon
           (This command must be run interactively)
GRASS-GRID>
An if I follow the interactivity choosing the monitor listing option the
response is the same!
thanks for your help
marino
               Flavio Poggi
   Dipartimento di Scienze della Terra
          Università di Genova
            Corso Europa, 26
          16132 GENOVA (Italy)
Tel.: +39 10 3538039
Fax : +39 10 352169
E-Mail: poggi@dister.unige.it
              HI MATES!!!!!
I had this same problem, on Solaris 2.5.1, using the binary distribution.
My solution was to copy d.mon over from the SunOS binaries that I have
running on another box. It now works.
Make sure that the binary compatibility package is installed.
Angus Carr.
Masters of Forestry student
On Fri, 11 Apr 1997 zucco@dister.unige.it wrote:
Hi grassusers,
moon /outgoing).
grass responds:
Usage:
      d.mon
GRASS-GRID>
marino
               Flavio Poggi
            Corso Europa, 26
Fax : +39 10 352169
              HI MATES!!!!!
