The sys op followed the recommendation and commented out termlib from
the main make file. We're not quite there...
Well, it seemed to take longer than before to fail, but I still have one
of the problems we had before: if I get rid of the TERMLIB line, it ends
up with some undefined symbols.
solaris2.6/libvask.a -lcurses -lm
Undefined first referenced
symbol in file
tgetnum /usr/ucblib/libcurses.a(cr_tty.o)
tgetstr /usr/ucblib/libcurses.a(cr_tty.o)
tgoto /usr/ucblib/libcurses.a(cr_put.o)
tputs /usr/ucblib/libcurses.a(endwin.o)
tgetent /usr/ucblib/libcurses.a(cr_tty.o)
tgetflag /usr/ucblib/libcurses.a(cr_tty.o)
ld: fatal: Symbol referencing errors. No output written to
/usr/local/grac/bin/main/inter/d.3d
*** Error code 1
make: Fatal error: Command failed for target
`/usr/local/grass42/etc/bin/ter/d.3d'
GISGEN failure at STEP: src/display/d.3d
Any thoughts?
Thanks for the previous response - we're almost there,
Maribeth
To: <grass@cecer.army.mil>
Subject: Re: grass termlib problems
Date: Tue, 20 Apr 1999 21:33:13 -0600Looks like you are using solaris. Comment out the comment out the TERMLIB
statement#TERMLIB = -ltermlib
this should work.
attached is my header file for solarisx86 2.6. It should also work for the
sparc version of solaris-----Original Message-----
To: grassu-list@cecer.army.mil <grassu-list@cecer.army.mil>
Date: Tuesday, April 20, 1999 7:10 PM
Subject: grass termlib problemsCan anyone help us with the following problem?...
If we specify "-ltermlib" for the TERMLIB option while running the setup
script (the relevant part of the "head" file is below), then we get a
compiler error telling us that there are multiple definitions for
Def_term. However, if we leave that option blank, we get "undefinedsymbol"
errors. The multiple definition errors are pasted below.
TERMLIB = -ltermlib
CURSES = -lcurses $(TERMLIB)
MATHLIB = -lmCompile error:
/usr/ucb/cc -s -o /usr/local/grass42/etc/bin/main/inter/d.3d OBJ/main.o
OBJ/threed.o OBJ/transform.o OBJ/clip.o OBJ/get_range.o OBJ/check_opt.o
OBJ/get_inputs.o OBJ/sigint.o OBJ/get_row.o OBJ/draw_face.o
/home/jenny/src42/src/libes/LIB/libD.a
/home/jenny/src42/src/libes/LIB/libdisplay.a
/home/jenny/src42/src/libes/LIB/libraster.a
/home/jenny/src42/src/libes/LIB/libgis.a
/home/jenny/src42/src/libes/LIB/libvask.a -lcurses -ltermlib -lm
ld: fatal: symbol `Def_term' is multiply defined:
(file /usr/ucblib/libcurses.a(curses.o) and file
/usr/ccs/lib/libtermlib.a(setupterm.o));
ld: warning: symbol `ttytype' has differing sizes:
(file /usr/ucblib/libcurses.a(curses.o) value=0x32; file
/usr/ccs/lib/libtermlib.a(setupterm.o) value=0x400);
/usr/ccs/lib/libtermlib.a(setupterm.o) definition taken
ld: fatal: File processing errors. No output written to
*** Error code 1
`/usr/local/grass42/etc/bin/main/inter/d.3d'
GISGEN failure at STEP: src/display/d.3dTIA,
Maribeth
Attachment Converted: "d:\eudora\attach\solaris"
