grass termlib problems
Looks like you are using solaris. Comment out the comment out the TERMLIB
statement
#TERMLIB = -ltermlib
this should work.
attached is my header file for solarisx86 2.6. It should also work for the
sparc version of solaris
-----Original Message-----
To: grassu-list@cecer.army.mil <grassu-list@cecer.army.mil>
Date: Tuesday, April 20, 1999 7:10 PM
Subject: grass termlib problems
Can anyone help us with the following problem?...
If we specify "-ltermlib" for the TERMLIB option while running the setup
script (the relevant part of the "head" file is below), then we get a
compiler error telling us that there are multiple definitions for
Def_term. However, if we leave that option blank, we get "undefined
symbol"
errors. The multiple definition errors are pasted below.
TERMLIB = -ltermlib
CURSES = -lcurses $(TERMLIB)
MATHLIB = -lm
Compile error:
/usr/ucb/cc -s -o /usr/local/grass42/etc/bin/main/inter/d.3d OBJ/main.o
OBJ/threed.o OBJ/transform.o OBJ/clip.o OBJ/get_range.o OBJ/check_opt.o
OBJ/get_inputs.o OBJ/sigint.o OBJ/get_row.o OBJ/draw_face.o
/home/jenny/src42/src/libes/LIB/libD.a
/home/jenny/src42/src/libes/LIB/libdisplay.a
/home/jenny/src42/src/libes/LIB/libraster.a
/home/jenny/src42/src/libes/LIB/libgis.a
/home/jenny/src42/src/libes/LIB/libvask.a -lcurses -ltermlib -lm
ld: fatal: symbol `Def_term' is multiply defined:
       (file /usr/ucblib/libcurses.a(curses.o) and file
/usr/ccs/lib/libtermlib.a(setupterm.o));
ld: warning: symbol `ttytype' has differing sizes:
       (file /usr/ucblib/libcurses.a(curses.o) value=0x32; file
/usr/ccs/lib/libtermlib.a(setupterm.o) value=0x400);
       /usr/ccs/lib/libtermlib.a(setupterm.o) definition taken
ld: fatal: File processing errors. No output written to
*** Error code 1
make: Fatal error: Command failed for target
`/usr/local/grass42/etc/bin/main/inter/d.3d'
GISGEN failure at STEP: src/display/d.3d
TIA,
Maribeth
(attachments)
solaris (1.24 KB)
