Dear Gregg:
I'm including my explination of how to get GRASS files
into Arc/Info at the end of this message.
This list of steps describes a polygon file transition,
but it's similar if you want to get line attributes.
Most of this you've already done, but I'll include my entire step
by step proceedure so it will make sense. Steps 2 and 3
describe what needs to be done to the category file and
.txt file before importation into Arc Info.
If you have any questions, feel free to call me.
We've done this many times, with great success.
My list of steps was written for my own use and I
may be leaving out steps that are intuitive to me.
So let me know if this works for you.
A few things to remember...
1- ArcInfo will not recognize directories or filenames
that contain capital letters.
2- ArcInfo has trouble with files that begin with a number.
3- Always use all capital letters when working in INFO.
I think there is an explination of the conversion on the GRASS
FTP site as well, but I've never actually looked for it.
I hope you this will help you!
Good Luck!
Stephanie
Stephanie L. Miller - Physical Scientist
U.S. Army Corps of Engineers, Fort Worth
CESWF-PL-RE
819 Taylor Street
P.O. Box 17300
Fort Worth, Texas 76102-0300
email: stephan@alla.pl.swf.usace.army.mil
phone: (817)334-2095
fax: (817)885-7539
All comments are my own and do
not represent official poilcy.
How to bring GRASS vector files into ARC/INFO and maintain polygon attributes..
1. In GRASS use
v.out.arc type=polygon vect=<GRASS filename> arc_prefix=<arc filename>
This command will produce 3 files in the "arc" directory of the
current mapset.
<filename>.pol = coordinate defintions of the lines defining the polygons
<filename>.lab = coordinates of the label points
<filename>.txt = a record # (arbitrary), category #, arc-id,
and category name
2. For easy import into INFO, you must change the <filename>.txt file so
that only the arc-id, and category# remain. The following awk statement
will do this and add a comma delimeter to the file.
awk '{print $3 "," $2}' <filename>.txt > <filename>.txt2
This will make a new file called <filename>.txt2 in the following format
arc-id,cat_num
3. To get the full category names you will need to copy the dig_cats file
to a new file (call it <newfilename>.txt3). Delete the first 4 lines
of this file and change the delimeter to from ":" to ",".
I find it easiest to use the text editor VI to do this step.
open the file
a. vi <newfilename>.txt3
delete first 4 lines
b. 4dd
then change the ":" delimeter to a ","
c. :g/:/s//,/g
save and quit
d. ZZ
4. In ARC use GENERATE to create an ARC/INFO coverage.
generate <newfilename>
Generate: input <arc_prfix>.pol
Generate: lines
Generate: input <arc_prefix>.lab
Generate: points
Generate: q
5. Create polygon topology using BUILD
BUILD <newfilename> poly
6. In INFO define 2 new files called <newfilename>.dat1 and <newfilename>.dat2
Then add the information from your ascii files into the new INFO files.
a. DEFINE <newfilename>.DAT1
ITEM NAME> <newfilename>-id,4,5,B,0
ITEM NAME> CATNUM,7,7,N,O
Note: The item definition for the
<newfilename>-id must be exactly the same
in all info files (4,5,B,0) in order to be
able to join them.
b. ADD FROM <filename>.TXT2 <ERRORFILE>.ERR
Note: You may need to give the full path
to these files in order
for INFO to find them.
c. DEFINE <NEWFILENAME>.DAT2
ITEM NAME> CATNUM,7,7,N,0
ITEM NAME> NAME,50,50,C
d. ADD FROM <filename>.TXT3 <ERRORFILE>.ERR
e. Q STOP will get you out of INFO.
7. Join the new .dat files to the .pat file you created in step 4.
a. Join the category numbers to the -ids...
Joinitem <newfilename>.pat <newfilename>.dat1 <newfilename>.pat
<newfilename>-id <newfilename>-id
b. Join the category names to the category numbers...
Joinitem <newfilename>.pat <newfilename>.dat2 <newfilename>.pat CATNU
M
CATNUM
8. Build polygon topology a second time...
build <newfilename> poly
9. You will need to define the projection (if you want to keep a record of it)
with the PROJECTDEFINE command in ARC.
For example - if your GRASS file is in UTM projection, zone 13, the followi
ng
command will encode the appropriate information on the AI fil
e.
a. PROJECTDEFINE COVER <newfilename>
Project: projection UTM
Project: zone 11
Project: units meters
Project: spheroid clarke1866
Project: parameters
