GRASS Transportability ?
Hi there,
   I am in the midst of tracking down some code for some
terrain modeling. I keep bumping into GRASS as the "ultimate answer" BUT
my needs tend to center around a portable set of code for several platforms.
My understanding is that GRASS is designed to work only on Medium-Iron, i.e.
UNIX workstations and uses MOtif and XLib calls.
Some quick questions:
[1] What flavor of C is GRASS written in ? ANSI or K&R ?
  K&R, I'd say.
[2] Are the display calls suffieciently isolated that a port to another
display system would be manageable ?
  Very much so. It took me half a day (being completely new to GRASS)
  to make a port to Apollo GPR (well, I didn't test it a lot,
  but d.rast and d.vect worked just fine...)
[3] Has anyone tried compiling GRASS using a C++ Compiler.
  Yes and no. I use GRASS libraries from C++, but there doesn't
  seem to be much point in compiling pure C code with a C++ compiler
  (new reserved words and such like).
  You need function prototypes for using GRASS functions from C++,
  these can be generated/extracted fairly efficiently using the
  GNU protoize tool together with good old vi.
  I've done this for most of the libraries, let me know if you want them.
  Martin
Martin Ameskamp, Inst. f. Informatik I (Computing Dept.)
Kiel University, Olshausenstr. 40, 24118 Kiel, Germany
Fax: ++49 431 8804054, Voice: ++49 431 8804474,
email: ma@informatik.uni-kiel.d400.de
