[GRASS-user] 0 points loaded in v.surf.idw
I’m trying to import some points from Postgres and convert it into raster using v.in.ogr and v.surf.idw
v.in.ogr dsn=“PG:host=tsf.noblis.org dbname=gis port=5433” layer=regcm.huss_monavg_2038 output=huss_monavg_2038_395_875 where=‘timestamp=395.875’
v.surf.idw input=huss_monavg_2038_395_875 column=huss output=rast_huss_monavg_2038_huss395_875
When I run the v.surf.idw, I get
13936 records selected from table
0 points loaded
ERROR: No data points found
When I try to view it in the map display, I see nothing yet I do see 13936 points which is the right number of points when I do v.info.
v.info huss_monavg_2038_395_875
Layer: huss_monavg_2038_395_875 |
| Mapset: PERMANENT |
| Database: /data/grassdata/echang |
| Title: |
| Map scale: 1:1 |
| Map format: native |
| Name of creator: echang |
| Organization: |
| Source date: Tue Jul 13 15:44:59 2010 |
| Type of Map: vector (level: 2) |
| Number of points: 13936 Number of areas: 0 |
| Number of lines: 0 Number of islands: 0 |
| Number of boundaries: 0 Number of faces: 0 |
| Number of centroids: 0 Number of kernels: 0 |
| Map is 3D: No |
| Number of dblinks: 1 |
| Projection: Lat/Lon |
| N: 70:15:29.96521N S: 19:27:00.387268N |
| E: 35:43:20.669862W W: 157:42:49.097902W |
| Digitization threshold: 0 |
| Comments: |
It is a large file so I tried making the region quite small
zone: 0
datum: nad83
ellipsoid: grs80
north: 70:15:29.96521N
south: 69N
west: 120W
east: 110W
nsres: 0:15:05.993042
ewres: 0:20
rows: 5
cols: 30
cells: 150
Is there a problem with the resolution? Any ideas?
Elizabeth
Elizabeth Chang
Lead
Noblis
3150 Fairview Park Drive Sourth
Falls Church, VA 22042
703-610-2321 (office)
elizabeth.chang@noblis.org
Noblis
For the best of reasons
On Tue, Jul 13, 2010 at 10:27 PM, Chang, Elizabeth
<Elizabeth.Chang@noblis.org> wrote:
v.in.ogr dsn="PG:host=tsf.noblis.org dbname=gis port=5433"
where='timestamp=395.875'
Please post a snippet of the output or check it yourself of
v.db.select huss_monavg_2038_395_875
just to be sure that you got the data actually in which you want to be in.
Furthermore,
.... map extent:
... computational (current) region extent;
south: 69N
west: 120W
east: 110W
ewres: 0:20
The "south" value of the computational region does not quite cover
the map (intentionally?). Likeweise east and west. (also the pixels
are non-square).
Perhaps you want to first use (set resolution as appropriate):
g.region vect=huss_monavg_2038_395_875 res=0:20 -a
to better fit the computational region to the map, then run v.surf.idw.
hope this helps,
