Hi Emmanuel,
I have 3hourly rainrate data for a given region in a GRASS temporal
database (strds).
I want to aggregate the data by summing all raster from the previous
10 days to calculate the accumulated rainfall.
The temporal modules have several tools:
t.rast.series
t.rast.accumulate
t.rast.aggregate
t.rast.mapcalc
From the manual, the appropriate module seems to be t.rast.accumulate
but it does not have sum in the method parameters. Currently, I’m
running several r.series commands for each day like below:
r.series input=
“t.rast.list input=3hr_rainrate where=\ "('${DATE} 00:00:00' >= datetime(start_time, '3 hours')) \ and ('${DATE} 00:00:00' <= datetime(start_time, '10 days')) " \ col=name method=comma
output=“test_2014-07-20” method=sum
Then, register each layer in another strds:
#Create a new STRDS
t.create output=‘10day_accumulation’ type=‘strds’ temporaltype=‘absolute’
title=‘10day_accumulation’
description=“10 day rainfall accumulation”
g.mlist type=‘rast’, pattern=‘test*’, separator=‘,’
#Register the r.series output to the strds
t.register -i type=rast input=10day_accumulation
start=“2014-07-10 00:00:00” increment=“1 days” separator=“,”
maps=“g.mlist type='rast', pattern='test*', separator=','
Is there another approach using directly any of the t.rast.* modules.
For a time-line visualization, here’s what I want to do:
https://dl.dropboxusercontent.com/u/2096185/sample_accumulation.png
Thanks!
If i understood right, something like
t.rast.aggregate input=3hr_rainrate output=10day_rain basename=10day_rain granularity=‘10 days’ method=sum
should do the what you need.
HTH,
Vero
Dear Vero,
Thanks for the reply. But t.rast.aggregate does not do what I intend
to do. My rainrate is from a span of 20 days.
t.rast.aggregate produces (as expected) two rasters, one for each of
the 10day accumulation. What I want for example is like a moving sum,
where for each day, it calculates the sum for the past 10 days.
On Thu, Dec 4, 2014 at 4:31 AM, Veronica Andreo <veroandreo@gmail.com> wrote:
Hi Emmanuel,
database (strds).
t.rast.series
t.rast.accumulate
t.rast.aggregate
t.rast.mapcalc
but it does not have sum in the method parameters. Currently, I'm
r.series input=\
"`t.rast.list input=3hr_rainrate where=\
col=name method=comma`" \
output="test_2014-07-20" method=sum
#Create a new STRDS
t.create output='10day_accumulation' type='strds' temporaltype='absolute'
title='10day_accumulation' \
description="10 day rainfall accumulation"
t.register -i type=rast input=10day_accumulation \
start="2014-07-10 00:00:00" increment="1 days" separator="," \
maps="`g.mlist type='rast', pattern='test*', separator=','`"
For a time-line visualization, here's what I want to do:
Thanks!
granularity='10 days' method=sum
HTH,
Vero
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
Hi Maning,
i think that the combination of t.rast.aggreagte and the new
t.rast.algebra will help you here. Be aware that you will need the
latest grass7.1 trunk version for this.
First you need to compute the daily rainfall sum with
t.rast.aggregate. All 3h map layer that are temporally contained in
the 1 day granule are summed up:
t.rast.aggregate input=3hr_rainrate output=prec1d method=sum
granularity="1 day" basename=prec1d sampling=contains
Then you need to use a temporal moving window of 9 day size in the
past (including the current layer that will be 10 map layers). The
granularity is one day so we can use the temporal neighbor index to
address the past map layers. Be aware that the "result" strds will
only contain map layers that have 9 map layers in the past:
t.rast.algebra basename="10d_acc" expression="result = prec1d[0] +
prec1d[-1] + ... + prec1d[-9]"
The temporal raster algebra module is very experimental, but i hope
that this will work.
Best regards
Soeren
ps.: The code is untested
2014-12-04 3:47 GMT+01:00 maning sambale <emmanuel.sambale@gmail.com>:
Dear Vero,
Hi Emmanuel,
database (strds).
t.rast.series
t.rast.accumulate
t.rast.aggregate
t.rast.mapcalc
r.series input=\
#Create a new STRDS
Thanks!
HTH,
Vero
cheers,
maning
grass-user mailing list
grass-user@lists.osgeo.org
Oh, I see... then, t.rast.accumulate is what you need. The default method
"mean" does the sum.
So "mean" is actually sum?
Maybe, something like this (please re-check the cycle and granularity
parameters, i didn't test)
t.rast.accumulate input=3hr_rainrate output=10day_acum_precip
base=10day_acc_prec start="2001-01-01" end="2001-01-20" cycle="10 days"
granularity="1 days" method=mean
I tried this, "end" should be "stop"
t.rast.accumulate --overwrite input=10day_hourly
output=10day_accumulation base=10day_accumulation \
start="2014-11-04 11:00:00" stop="2014-12-04 11:00:00" cycle="10 days"
The process wouldn't stop, my area is very small so I expect it to
finish in less than an hour:
g.region -p
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 22N
south: 4N
west: 115E
east: 155E
nsres: 0:15
ewres: 0:15
rows: 72
cols: 160
cells: 11520
cheers,
maning
Dear Soeren,
Thanks will try this.
cheers,
maning
