[GRASS-user] 2 questions about usage of g.region
HEy
I have three questions:
1- Is it possible to define active region spatial resolution by selecting an image instead of putting values?
2- What is done with -a flag?
3- Just to confirm this, when an image is imported with r.in.gdal it is kept with its original resolution right? it only gets the active region spatial resolution when I process it right (e.g. mapcalc or somethingg)
Thanks
Kat
katrin eggert wrote:
HEy
Using a grass raster, yes. g.region rast=…
If you have , i.e. a resolution of 5 meters and the E-W extent is 99 meters, then with the -a flag the region will be reset to 100 m. Without the -a flag, the resolution will be recalculated so that it fits into the extents. So in the above case, without -a, the E-W res will be changed to 4.95
AFAIK, yes.
somethingg)
AFAIK, yes.
About which raster modules respect or ignore the current region, you could read some mails from Spetember last year, starting from here:
http://lists.osgeo.org/pipermail/grass-user/2010-September/057988.html
Hermann
Thanks Micha and Hermann for your feedback.
Just one very last question: in a Python script how can I make an variabel to equal to an image spatial resolution? (I mean, How can I retrieve an image spatial resolution)?
THanks
Best regards,
Kat
2011/2/3 Micha Silver <micha@arava.co.il>
HEy
AFAIK, yes.
Thanks
Kat
This mail was received via Mail-SeCure System.
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
There is some very good documentation on Python and GRASS. I hope
this helps. http://grass.osgeo.org/wiki/GRASS_and_Python
Mark
On Thu, Feb 3, 2011 at 9:57 AM, katrin eggert
THanks
Best regards,
Kat
HEy
Using a grass raster, yes. g.region rast=....
4.95
AFAIK, yes.
Thanks
Kat
2011/2/3 katrin eggert <katrineggert1980@gmail.com>:
raster_info() [1] e.g.
info = raster_info(map)
print info['nsres'], info['ewres']
Martin
[1] http://grass.osgeo.org/programming7/namespacepython_1_1raster.html#a69e4a61eb59a31608410b733d174b8a7
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
You can also use your mouse. Load your image in the Layer manager, right
click on this map and select "Set computational region from selected map".
Thibault.
