[GRASS-user] 25 yr celebration
Another logo for the 25 yr celebration of Grass Gis
http://grass.osgeo.org/wiki/File:Grass_logo_gold_text_25yr_celebration.png
Have 25yr happy anniversary.
Javier García.
Windows Live Hotmail: Your friends can get your Facebook updates, right from Hotmail®.
is there a way in GRASS to build an accumulation map from a directions
map without a dem map?
Best regards,
Achim
2009/11/18 javier Garcia Prieto <fjgarciaprieto@hotmail.com>:
Cool, just try to keep
http://grass.osgeo.org/wiki/GRASS_Art_Gallery
up-to-date (ie. add this file to the gallery). Otherwise it can be lost.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
25 year is a long time.
I have been working with GRASS for 5 years and I still haven’t found nothing you can’t do with GRASS.
Thank you very much for the developers and users who help.
Pablo Torres Carreira
Brazil
Making a LOT of thematic maps for ambiental purposes.
Date: Wed, 18 Nov 2009 17:48:32 +0100
Subject: Re: [GRASS-user] 25 yr celebration
To: fjgarciaprieto@hotmail.com
CC: grass-user@lists.osgeo.org
2009/11/18 javier Garcia Prieto fjgarciaprieto@hotmail.com:
Martin
grass-user mailing list
Chegou o Windows 7: Incrivelmente simples! Clique e conheça.
Hello again,
I am still searching a method to generate a flow accumulation map from a
flow direction map.
I got the direction map from an arcgis user. In arcgis the module
"FLOWACCUMULATION(FLOW_DIR)" would do this, but I want to use an open
source solution.
If anyone could give me a hint, where I could find a tool like this
(inside GRASS it does not seem to be possible), I would be very grateful.
Best regards,
Achim
Achim Kisseler pisze:
Hello again,
flow direction map.
source solution.
Best regards,
Achim
there shoud be no problem if you have oryginal DEM
Thanks, Jaroslaw for response,
I know, but I do NOT have the DEM. Thats the problem.
Achim
Hello again,
flow direction map.
source solution.
Best regards,
Achim
Hi Achim,
if you are trying to use an open source GIS for hydrological applications consider to take a look at JGrass. There are a lot of geomorphological modules.
Best regards
Silvia
Hello again,
flow direction map.
source solution.
Best regards,
Achim
Hi Silvia,
thank you very much. I will use h.tca from JGRASS to get the desired.
Best,
Achim
Silvia Franceschi schrieb:
Hi Achim,
Best regards
Silvia
Hello again,
flow direction map.
source solution.
Best regards,
Achim
2009/11/19 Achim Kisseler <ak7@jupiter.uni-freiburg.de>:
Ah, now I understand "is there a way in GRASS to build an
accumulation map from a directions map without a dem map?"
So: If you are on earth, you can get it here (mars/moon should be also
available somewhere :-):
http://grass.osgeo.org/wiki/Global_datasets
- SRTM
- ASTER GDEM
especially
http://grass.osgeo.org/wiki/ASTER_topography
If you need to start from the accumulation map and no way to
use a DEM, then I have no idea (but see the other comments)
Hope this helps,
Dear Markus,
I follow Silvias suggestion and use h.tca in JGRASS.
BTW: Isn't is possible to integrate the horton-tools into grass?
Achim
- SRTM
- ASTER GDEM
especially
Hope this helps,
On Thu, Nov 19, 2009 at 2:35 PM, Achim Kisseler
<ak7@jupiter.uni-freiburg.de> wrote:
Dear Markus,
If the license is compliant to GPL (I guess so), yes.
Hi Markus,
Horton Machine licence is LGPL and written in Java...
Silvia
Markus Neteler pisze:
Dear Markus,
Hortons tools are available in svn add ons as r.stream.* suite: r.stream.extract, r.stream.order, r.stream.stats etc... see tutorial on grass wiki
http://grass.osgeo.org/wiki/R.stream.*
Jarek
again I reached the point I did half a year ago: jgrass only can handle 'metric' rasters, which means raster-cells of equal sizes, same NS, OW resolution.
I work an a latlon-projection and therefore I cannot use jgrass.
? 1 I guess, r.stream cannot handle latlong-projections?
? 2 I guess, r.stream doesn't have something like h.tca?
     (h.tca: makes an accumulation map from a direction map)
? 3 Is it possible to make the accumulation-values non-integer and weight every grid-cell with its real area size? Then every accumulation value would indicate its basin-size and so on like in eg. lambert projection.
What wouldn't work that easy: distances EW and thus angle based calculations, too.
Again my old PROBLEM:
How to get an accumulation map strickly WITHOUT an DEM from ONLY an direction map on a LAT-LON map?
Achim
Dear Markus,
Jarek
