I have a 2D polygon file containing building data which is associated with height values (within attribute table). Is it possible to create a 3D-vector/raster file from that file. And how to do it? Hence I would like to drape it over a DEM both in 3D!
Any suggestions?
Regards
Christian
Invite your mail contacts to join your friends list with Windows Live Spaces. It’s easy! Try it!
On Mon, Sep 15, 2008 at 10:38 AM, christian Brandt
<chrisbrandt74@hotmail.com> wrote:
Dear list,
Any suggestions?
Sure (example for North Carolina data set):
Note: v.extrude requires polygons as input to extrude to 3D house blocks:
# convert lines to boundaries (may not be needed in your case)
# add centroids (may not be needed in your case):
v.type bldg_resid out=bldg_resid_bnd type=line,boundary
v.centroids bldg_resid_bnd out=bldg_resid_pol
v.type bldg_cmcl out=bldg_cmcl_bnd type=line,boundary
v.centroids bldg_cmcl_bnd out=bldg_cmcl_pol
