I am trying to make a scenery for a soaring simulation game (silentwings).
The common way to do this is combining RGB landsat7 bands (Tm3,2,1), then
pan-sharpen this combination. So far I was able to do pan-sharpening using
grass, but I was advised (and asked by the program) to choose the NIR and
MIR bands. In that case I get kind of funny colors (purple roads, deep blue
rivers etc), not really usable for the game. Can I do the same but then with
the RGB bands? Do i need a different approach or can I use the same using
band Tm3,2,1. Which band do i substitute for which?
On Thu, 7 Feb 2008 12:57:14 -0800 (PST)
Reno Bladergroen <Rbladergroen@tele2allin.be> wrote:
Hello list,
(silentwings). The common way to do this is combining RGB landsat7
bands (Tm3,2,1), then pan-sharpen this combination. So far I was able
to do pan-sharpening using grass, but I was advised (and asked by the
program) to choose the NIR and MIR bands. In that case I get kind of
funny colors (purple roads, deep blue rivers etc), not really usable
for the game. Can I do the same but then with the RGB bands? Do i
need a different approach or can I use the same using band Tm3,2,1.
Thanks in advance,
Reno
The use of Near and Mid infrared bands is recommended for extracting
information from the image, particularly about vegetation and water.
To find the bands of the landsat 7 image that correspond to RGB, you
would have to look at the metadata for the image, but they are probably
bands 3,4,5.
All functions within grass should function the same no matter
which bands are given as input values.
> Hello list,
> Thanks in advance,
> Reno
bands 3,4,5.
Ususally:
1: B
2: G
3: R
4: NIR
5: MIR1
6: TIR
7: MIR2
