[GRASS-user] 3D raster color coding
I have created a 3D raster from soil properties with about 70K points, with a lot of help from the mailing list i must say.
from the copy of the metadata of the 3d raster (below) it would confirm that the 3D raster worked and the grid is populated with data.
I have copied below the r3.colors and assigned ‘aspectcolr’ as a trial. Unfortunately in the Display window nothing shows up, whether in 2D or in 3D view. I do not know what i am doing incorrectly.
Once I am done and able to develop the 3D raster of the soil properties, I will prepare a simple step by step for developing such a raster which may be useful for others.
| Layer: BHALL_May24v2@Toronto Date: Sun May 27 16:43:46 2018 |
| Mapset: Toronto Login of Creator: Francois Charti |
| DataBase: C:\Users\Francois Chartier\Documents\grassdata |
| Title: BHALL_May24v2 |
| Units: none |
| Vertical unit: units |
Timestamp: none
Type of Map: raster_3d Number of Categories: 0
Data Type: FCELL
Rows: 90
Columns: 85
Depths: 307
Total Cells: 2348550
Total size: 3180868 Bytes
Number of tiles: 336
Mean tile size: 9466 Bytes
Tile size in memory: 30420 Bytes
Number of tiles in x, y and z: 6, 7, 8
Dimension of a tile in x, y, z: 15, 13, 39
Projection: UTM (zone 17)
N: 4870795 S: 4825715 Res: 500.88888889
E: 651669 W: 609204 Res: 499.58823529
T: 352 B: 45 Res: 1
Range of data: min = -8.99099445 max = 33.89262009
Data Source:
Data Description:
generated by v.vol.rst
Comments:
v.vol.rst input=“BHMat1All_May12@Toronto” wcolumn=“cat” tension=40. \
smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=2 wscale=1.0 zscale=1.\
0 elevation=“BHALL_May24v2”
(Wed May 30 21:11:59 2018) Command finished (0 sec)
(Wed May 30 21:10:02 2018)
r3.colors map=BHALL_May24v2@Toronto color=aspectcolr
Color table for raster3d map BHALL_May24v2@Toronto set to ‘aspectcolr’
(Wed May 30 21:10:03 2018) Command finished (0 sec)
Hello,
That’s probably because that palette is for integer values ranging from 0 to 360 [0]. Try with a relative one such as viridis or bcyr.
HTH,
Vero
[0] https://grass.osgeo.org/grass74/manuals/r.colors.html
El jue., 31 may. 2018 a las 3:18, Francois Chartier (<fra.chartier@gmail.com>) escribió:
| Units: none |
Timestamp: none
Data Type: FCELL
Rows: 90
Columns: 85
Depths: 307
T: 352 B: 45 Res: 1
Data Source:
Data Description:
Comments:
grass-user mailing list
grass-user@lists.osgeo.org
Thanks, I’ll check it out.
On Fri, Jun 1, 2018, 03:05 Veronica Andreo, <veroandreo@gmail.com> wrote:
Hello,
HTH,
Vero
| Units: none |
Timestamp: none
Data Type: FCELL
Rows: 90
Columns: 85
Depths: 307
T: 352 B: 45 Res: 1
Data Source:
Data Description:
Comments:
Try removing -r from your command (unchecking the box in the GUI).
That flag is used to remove a color palette.
Best,
Vero
El sáb., 2 jun. 2018 3:48, Francois Chartier <fra.chartier@gmail.com> escribió:
Hi Veronica,
something is odd. here are the steps - Display window is still blank and the 3D raster has data ranging from -8 to 34.
Step 2 - set as viridis - according to manual this
result in command window
(Fri Jun 01 21:44:05 2018)
r3.colors -r map=BHALL_May24v2@Toronto color=viridis
(Fri Jun 01 21:44:05 2018) Command finished (0 sec)
Display is still blank.
Data is there
| Type of Map: raster_3d Number of Categories: 0 |
| Data Type: FCELL |
| Rows: 90 |
| Columns: 85 |
| Depths: 307 |
| Total Cells: 2348550 |
| Total size: 3180868 Bytes |
| Number of tiles: 336 |
| Mean tile size: 9466 Bytes |
| Tile size in memory: 30420 Bytes |
| Number of tiles in x, y and z: 6, 7, 8 |
| Dimension of a tile in x, y, z: 15, 13, 39 |
| Projection: UTM (zone 17) |
| N: 4870795 S: 4825715 Res: 500.88888889 |
| E: 651669 W: 609204 Res: 499.58823529 |
| T: 352 B: 45 Res: 1 |
| Range of data: min = -8.99099445 max = 33.89262009 |
| Data Source: |
| Data Description: |
| generated by v.vol.rst |
| Comments: |
| v.vol.rst input=“BHMat1All_May12@Toronto” wcolumn=“cat” tension=40. \ |
| smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=2 wscale=1.0 zscale=1.\ |
Le ven. 1 juin 2018 à 12:54, Francois Chartier <fra.chartier@gmail.com> a écrit :
Hello,
HTH,
Vero
| Units: none |
Timestamp: none
Data Type: FCELL
Rows: 90
Columns: 85
Depths: 307
T: 352 B: 45 Res: 1
Data Source:
Data Description:
Comments:
Is there any way to set the range for the color table?
Best,
Vero
Hi Veronica,
Data is there
| Data Type: FCELL |
| Rows: 90 |
| Columns: 85 |
| Depths: 307 |
| Data Source: |
| Data Description: |
| Comments: |
Hello,
HTH,
Vero
| Units: none |
Timestamp: none
Data Type: FCELL
Rows: 90
Columns: 85
Depths: 307
T: 352 B: 45 Res: 1
Data Source:
Data Description:
Comments:
i removed the ‘r’ and used elevation and bcyr as the color tables, see below. Display window is blank.
to recap the steps:
1 - i selected the Mapset and also tried Map that corresponds to the 3d raster
2 - then in Define tab, i only choose the Name of Color Table: bcyr, i have not selected anything else,
3 - then i just Run.
(Sat Jun 02 13:45:02 2018)
r3.colors map=BHALL_May24v2@Toronto color=elevation
Color table for raster3d map BHALL_May24v2@Toronto set to ‘elevation’
(Sat Jun 02 13:45:02 2018) Command finished (0 sec)
(Sat Jun 02 13:46:14 2018)
r3.colors map=BHALL_May24v2@Toronto color=bcyr
Color table for raster3d map BHALL_May24v2@Toronto set to ‘bcyr’
(Sat Jun 02 13:46:15 2018) Command finished (0 sec)
Le sam. 2 juin 2018 à 09:01, Francois Chartier <fra.chartier@gmail.com> a écrit :
Best,
Vero
Hi Veronica,
Data is there
| Data Type: FCELL |
| Rows: 90 |
| Columns: 85 |
| Depths: 307 |
| Data Source: |
| Data Description: |
| Comments: |
Hello,
HTH,
Vero
| Units: none |
Timestamp: none
Data Type: FCELL
Rows: 90
Columns: 85
Depths: 307
T: 352 B: 45 Res: 1
Data Source:
Data Description:
Comments:
What about the region? Is it set to the extent of your raster?
El sáb., 2 jun. 2018 19:52, Francois Chartier <fra.chartier@gmail.com> escribió:
to recap the steps:
Best,
Vero
Hi Veronica,
Data is there
| Data Type: FCELL |
| Rows: 90 |
| Columns: 85 |
| Depths: 307 |
| Data Source: |
| Data Description: |
| Comments: |
Hello,
HTH,
Vero
| Units: none |
Timestamp: none
Data Type: FCELL
Rows: 90
Columns: 85
Depths: 307
T: 352 B: 45 Res: 1
Data Source:
Data Description:
Comments:
how do you ensure that region is selected to the extent of the raster. I think I already did this when making v.vol.rst.
to recap the steps:
Best,
Vero
Hi Veronica,
Data is there
| Data Type: FCELL |
| Rows: 90 |
| Columns: 85 |
| Depths: 307 |
| Data Source: |
| Data Description: |
| Comments: |
Hello,
HTH,
Vero
| Units: none |
Timestamp: none
Data Type: FCELL
Rows: 90
Columns: 85
Depths: 307
T: 352 B: 45 Res: 1
Data Source:
Data Description:
Comments:
g.region manual page:
https://grass.osgeo.org/grass74/manuals/g.region.html
print current region info
g.region -p
set to a raster 3d
g.region raster_3d=nameofyourmap
El sáb., 2 jun. 2018 19:58, Francois Chartier <fra.chartier@gmail.com> escribió:
to recap the steps:
Best,
Vero
Hi Veronica,
Data is there
| Data Type: FCELL |
| Rows: 90 |
| Columns: 85 |
| Depths: 307 |
| Data Source: |
| Data Description: |
| Comments: |
Hello,
HTH,
Vero
| Units: none |
Timestamp: none
Data Type: FCELL
Rows: 90
Columns: 85
Depths: 307
T: 352 B: 45 Res: 1
Data Source:
Data Description:
Comments:
C:\Users\Francois Chartier>g.region -p
projection: 1 (UTM)
zone: 17
datum: nad83
ellipsoid: grs80
north: 4870795
south: 4825715
west: 609204
east: 651669
nsres: 500.88888889
ewres: 499.58823529
rows: 90
cols: 85
cells: 7650
metadata from 3d raster
| Units: none |
Timestamp: none
Data Type: FCELL
Rows: 90
Columns: 85
Depths: 307
T: 352 B: 45 Res: 1
Data Source:
Data Description:
Comments:
g.region -p
set to a raster 3d
to recap the steps:
Best,
Vero
Hi Veronica,
Data is there
| Data Type: FCELL |
| Rows: 90 |
| Columns: 85 |
| Depths: 307 |
| Data Source: |
| Data Description: |
| Comments: |
Hello,
HTH,
Vero
| Units: none |
Timestamp: none
Data Type: FCELL
Rows: 90
Columns: 85
Depths: 307
T: 352 B: 45 Res: 1
Data Source:
Data Description:
Comments:
see export below of color tab.
(Sat Jun 02 14:11:39 2018)
r3.colors.out map=BHALL_May24v2@Toronto
-8.99099 0:0:255
5.30354 0:255:255
19.5981 255:255:0
33.8926 255:0:0
nv 255:255:255
default 255:255:255
(Sat Jun 02 14:11:39 2018) Command finished (0 sec)
Le sam. 2 juin 2018 à 14:05, Francois Chartier <fra.chartier@gmail.com> a écrit :
projection: 1 (UTM)
zone: 17
datum: nad83
ellipsoid: grs80
north: 4870795
south: 4825715
west: 609204
east: 651669
nsres: 500.88888889
ewres: 499.58823529
rows: 90
cols: 85
cells: 7650
| Units: none |
Timestamp: none
Data Type: FCELL
Rows: 90
Columns: 85
Depths: 307
T: 352 B: 45 Res: 1
Data Source:
Data Description:
Comments:
g.region -p
set to a raster 3d
to recap the steps:
Best,
Vero
Hi Veronica,
Data is there
| Data Type: FCELL |
| Rows: 90 |
| Columns: 85 |
| Depths: 307 |
| Data Source: |
| Data Description: |
| Comments: |
Hello,
HTH,
Vero
| Units: none |
Timestamp: none
Data Type: FCELL
Rows: 90
Columns: 85
Depths: 307
T: 352 B: 45 Res: 1
Data Source:
Data Description:
Comments:
and here is g.region -p3
projection: 1 (UTM)
zone: 17
datum: nad83
ellipsoid: grs80
north: 4870795
south: 4825715
west: 609204
east: 651669
top: 352.00000000
bottom: 45.00000000
nsres: 500.88888889
nsres3: 500.88888889
ewres: 499.58823529
ewres3: 499.58823529
tbres: 1
rows: 90
rows3: 90
cols: 85
cols3: 85
depths: 307
cells: 7650
cells3: 2348550
Le sam. 2 juin 2018 à 14:12, Francois Chartier <fra.chartier@gmail.com> a écrit :
-8.99099 0:0:255
5.30354 0:255:255
19.5981 255:255:0
33.8926 255:0:0
nv 255:255:255
default 255:255:255
projection: 1 (UTM)
zone: 17
datum: nad83
ellipsoid: grs80
north: 4870795
south: 4825715
west: 609204
east: 651669
nsres: 500.88888889
ewres: 499.58823529
rows: 90
cols: 85
cells: 7650
| Units: none |
Timestamp: none
Data Type: FCELL
Rows: 90
Columns: 85
Depths: 307
T: 352 B: 45 Res: 1
Data Source:
Data Description:
Comments:
g.region -p
set to a raster 3d
to recap the steps:
Best,
Vero
Hi Veronica,
Data is there
| Data Type: FCELL |
| Rows: 90 |
| Columns: 85 |
| Depths: 307 |
| Data Source: |
| Data Description: |
| Comments: |
Hello,
HTH,
Vero
| Units: none |
Timestamp: none
Data Type: FCELL
Rows: 90
Columns: 85
Depths: 307
T: 352 B: 45 Res: 1
Data Source:
Data Description:
Comments:
view. I do not know what i >am doing incorrectly.
see https://trac.osgeo.org/grass/ticket/3571
please add your findings there.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
I have pasted below the colors files for the 3d raster. the screen capture shows that the data is there as i am showing the wireframe around the data. the r3.color is set to bgyr. therefore, i do not see how come the interpolated data does not show up in the display.
r3.colors map=BHALL_May24v2@Toronto color=bgyr
Color table for raster3d map BHALL_May24v2@Toronto set to ‘bgyr’
color table - the data is associated with a color as per below.
% -8.9909944534301758 33.892620086669922
-8.9909944534301758:0:191:191 -0.41427154541015626:0:255:0
-0.41427154541015626:0:255:0 8.1624513626098629:255:255:0
16.739174270629881:255:127:0 25.315897178649902:191:127:63
25.315897178649902:191:127:63 33.892620086669922:200
8.1624513626098629:255:255:0 16.739174270629881:255:127:0
Metadata of 3d raster. - same range of data as color table.
| Data Type: FCELL |
| Rows: 90 |
| Columns: 85 |
| Depths: 307 |
| Data Source: |
| Data Description: |
| Comments: |
best regards
Helmut
(attachments)
the vector is visible in 3d as per attached screen shot. could this be a problem due to computer instead of Grass. there may be too many data points to show?
Le dim. 10 juin 2018 à 15:46, Francois Chartier <fra.chartier@gmail.com> a écrit :
| Data Type: FCELL |
| Rows: 90 |
| Columns: 85 |
| Depths: 307 |
| Data Source: |
| Data Description: |
| Comments: |
best regards
Helmut
(attachments)
I have pasted below the colors files for the 3d raster. The data is there as i am viewing the wireframe around the data. the r3.color is set to bgyr. therefore, i do not see how come the interpolated data does not show up in the display. any ideas?
Le dim. 10 juin 2018 à 15:57, Francois Chartier <fra.chartier@gmail.com> a écrit :
| Data Type: FCELL |
| Rows: 90 |
| Columns: 85 |
| Depths: 307 |
| Data Source: |
| Data Description: |
| Comments: |
best regards
Helmut
I sent you some time ago a video how to view 3D rasters using isosurfaces or slices:
https://youtu.be/CmK-fEyf2SY
If you haven’t added any isosurface or slice, you won’t see anything beside the 3D box.
Also, I recommend setting higher z-exaggeration.
Anna
On Mon, Jun 11, 2018 at 10:29 PM Francois Chartier <fra.chartier@gmail.com> wrote:
| Data Type: FCELL |
| Rows: 90 |
| Columns: 85 |
| Depths: 307 |
| Data Source: |
| Data Description: |
| Comments: |
best regards
Helmut
that worked! thank you. i can see the data using 3D view, in data tab, select 3d raster at bottom (scroll down), select 3d raster, draw: slices, shading flat, resolution 1, select wire box.
then i can add slices. I havent mastered the system yet but i think i am on the right track now. thank you very much!
Anna
| Data Type: FCELL |
| Rows: 90 |
| Columns: 85 |
| Depths: 307 |
| Data Source: |
| Data Description: |
| Comments: |
best regards
Helmut
here is a screen shot of the 3D view.
Le mar. 12 juin 2018 à 22:13, Francois Chartier <fra.chartier@gmail.com> a écrit :
here is a screen shot of the data set, ground surface, top bedrock, data points, 3d raster. still a lot of work but now i can move to the next step
Le mar. 12 juin 2018 à 21:55, Francois Chartier <fra.chartier@gmail.com> a écrit :
Anna
| Data Type: FCELL |
| Rows: 90 |
| Columns: 85 |
| Depths: 307 |
| Data Source: |
| Data Description: |
| Comments: |
best regards
Helmut
(attachments)
