I would like to remove voxels located at a higher elevation than DEM.
I have been trying r3.mapcalc without sucess.
Does the XY resolutions of both raster have to the same?
any ideas how to do this?
Thanks
Francois
Thanks
Francois
See attached screenshot, I was able to remove voxels above the DEM and below bedrock surface using r3.out.vtk and selecting export as pointdata (p) not voxels. If exported as a Voxel from r3.out.vtk, the voxel file did not open properly in Paraview could be due to size of file. I changed option to export as points and it is working.
grid resolution is 5 x 5 x 1 m over 4km x 4 km x 65 m thickness approx. (actual thickness varies between DEM and top of rock).
r3.out.vtk -p -s input=jan27551tens100@Toronto output=C:\Users\Francois Chartier\Documents\GeoModel\WorkingFile\Feb6_VTK_Pts top=GTADEM@Toronto bottom=rock@PERMANENT
Le mar. 5 févr. 2019 à 21:20, Francois Chartier <fra.chartier@gmail.com> a écrit :
grid resolution is 5 x 5 x 1 m over 4km x 4 km x 65 m thickness approx. (actual thickness varies between DEM and top of rock).r3.out.vtk -p -s input=jan27551tens100@Toronto output=C:\Users\Francois Chartier\Documents\GeoModel\WorkingFile\Feb6_VTK_Pts top=GTADEM@Toronto bottom=rock@PERMANENT
Le dim. 3 févr. 2019 à 16:42, Francois Chartier <fra.chartier@gmail.com> a écrit :
Thanks
Francois
Hi François,
Thanks for sharing the solution you found. From your first mail it was clear to me what these voxels above the DEM contained. NULL values ?
It would be great if you could summarize all your experience working on 3D data in GRASS GIS in the wiki, at least by amending https://grasswiki.osgeo.org/wiki/Help_with_3D with your additions or corrections ? This would be very helpful many others.
Moritz
On 6/02/19 03:46, Francois Chartier wrote:
See attached screenshot, I was able to remove voxels above the DEM and below bedrock surface using r3.out.vtk and selecting export as *pointdata (p)* not voxels. If exported as a Voxel from r3.out.vtk, the voxel file did not open properly in Paraview could be due to size of file. I changed option to export as points and it is working.
Le mar. 5 févr. 2019 à 21:20, Francois Chartier <fra.chartier@gmail.com <mailto:fra.chartier@gmail.com>> a écrit :
top=GTADEM@Toronto bottom=rock@PERMANENTLe dim. 3 févr. 2019 à 16:42, Francois Chartier
<fra.chartier@gmail.com <mailto:fra.chartier@gmail.com>> a écrit :Hi,
than DEM.
Thanks
Francois_______________________________________________
grass-user mailing list
grass-user@lists.osgeo.org
Thanks Moritz
My goal is to summarize the steps for 3d interpolation at the end of the process. it took me a year to get here and still have a few more steps to do which i will contact the User list for.
I am actually doing this as part of a 2nd master thesis with le Cnam in Paris as continuing education, so i will formalize the process.
The voxels above the dem are not Null values in this interpolation as the vvolrst interpolates the data within the full ‘footprint’ of the g.region; is there a possibility to constrain the interpolation to in between the DEM and lower surface, by setting a more customized Region than a Block?
On Feb 6, 2019 04:45, “Moritz Lennert” <mlennert@club.worldonline.be> wrote:
Hi François,
clear to me what these voxels above the DEM contained. NULL values ?It would be great if you could summarize all your experience working on
corrections ? This would be very helpful many others.Moritz
below bedrock surface using r3.out.vtk and selecting export aspointdata (p) not voxels. If exported as a Voxel from r3.out.vtk, the
bottom=rock@PERMANENTLe mar. 5 févr. 2019 à 21:20, Francois Chartier <fra.chartier@gmail.com
and below bedrock surface using r3.out.vtk and selecting export aspointdata (p) not voxels. If exported as a Voxel from r3.out.vtk,
<fra.chartier@gmail.com mailto:[fra.chartier@gmail.com](mailto:fra.chartier@gmail.com)> a écrit :
than DEM.
Thanks
Francois
On 6/02/19 14:02, Francois Chartier wrote:
Thanks Moritz
I am actually doing this as part of a 2nd master thesis with le Cnam in Paris as continuing education, so i will formalize the process.The voxels above the dem are not Null values in this interpolation as the vvolrst interpolates the data within the full 'footprint' of the g.region; is there a possibility to constrain the interpolation to in between the DEM and lower surface, by setting a more customized Region than a Block?
You could try r3.mask.
Moritz
On Feb 6, 2019 04:45, "Moritz Lennert" <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>> wrote:
Hi François,
DEM and
r3.out.vtk, the
approx.
top=GTADEM@Toronto
a écrit :>
the DEM
export as
r3.out.vtk,> the voxel file did not open properly in Paraview could be due to
working.
écrit :>
> Hi,
> than DEM.
> Thanks
> Francois
> grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
