[GRASS-user] 3D TIN?
Dear GRASS users,
I have a question about exporting TINs to dxf. I have successfully managed to perform the export and opened the TIN files created with v.delaunay in CAD. Problem is, the z value of the TIN points is 0 and my TIN is flat (not what I wanted to achieve). Am I doing something wrong or is this what should happen? Is there a command that would allow the export of 3D TINs? Is this an export problem only or is the command v.delaunay not producing a 3D file?
Hope my problem is clearly stated. Any suggestions on how to create and export a 3D TIN for further editing in software external to GRASS is welcome!
Yours
stefania merlo
University of Cambridge
UK
S. Merlo wrote:
Dear GRASS users,
v.info your_vector will tell if the vector is 3D or not. If it is, it
might be (not sure) that v.out.dxf flattens it at export.
If your CAD program can read shapefiles, export with v.out.ogr which
should preserve the third dimension.
Or, if you can import a txt list of 3D points into your CAD to build
the TIN from them, consider extracting your triangle nodes with
v.to.points -n as 3D points and export them with v.out.ascii
format=point into a text file.
Maciek
Stefania Merlo wrote:
Dear GRASS users,
(not
a
3D file?
welcome!
Yours
stefania merlo
UK
Hi Stefania,
I checked v.out.dxf and found that no 3DFACE support is there. This needs
to be added; I think it would be the inverse of
vector/v.in.dxf/add_3dface.c
View this message in context: http://www.nabble.com/3D-TIN--tf4040787.html#a11480693
Thank you Markus for the clarification.
Is there anybody out there that could assist the support for 3D face? I cannot program...
stefania
Dear GRASS users,
my TIN is flat (not
producing a
3D file?
welcome!
Yours
stefania merlo
UK
Hi Stefania,
http://www.nabble.com/3D-TIN--tf4040787.html#a11480693 Sent from the
grassuser mailing list
grassuser@grass.itc.it
Stefania,
do you really need to work with dxf files? Are you using AutoCAD or
other CAD software? AutoCAD MAP can import shapefiles.
if you really need dxf, you can try to export as shapefile and then convert it.
there are some converters around, like:
http://www.globalmapper.com/
http://www.guthcad.com/arcv2cad.htm
http://www.mass.gov/mgis/dxf.htm
these are Windows programs, though.
good luck
Carlos
cannot program...
stefania
>> Dear GRASS users,
>> my TIN is flat (not
>> producing a
>> 3D file?
>> welcome!
>> Yours
>> stefania merlo
>> UK
> Hi Stefania,
> Markus
              Carlos Henrique Grohmann - Guano
  Visiting Researcher at Kingston University London - UK
  Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Dear Carlos and all,
I tried the export via shapefile too, as I do actually have Autocad Map. The problem remains the same. For some reason (or actually, probably the same reason highlighted my Markus in previous correspondance) the v.out even in this case does not transfer 3D info.
I really need to work in 3D to edit these TINS and create a 3D geometry to then import in GRASS and Paraview. Can anybody assist? I am basically trying to create 3D irregular volumes from points to represent archaeological features.
Yours,
stefania
--On 08 July 2007 11:28 +0100 "Carlos \"Guâno\" Grohmann" <carlos.grohmann@gmail.com> wrote:
Stefania,
convert it.
good luck
Carlos
cannot program...
stefania
>> Dear GRASS users,
>> my TIN is flat (not
>> producing a
>> 3D file?
>> is welcome!
>> Yours
>> stefania merlo
>> UK
> Hi Stefania,
> needs to be added; I think it would be the inverse of
> Markus
_________________
Does the map you created with v.delaunay have 3D info? or is it a 2D
triangulation of your 3D points?
Carlos
Yours,
stefania
> Stefania,
> convert it.
> good luck
> Carlos
>> cannot program...
>> stefania
>> >> Dear GRASS users,
>> >> my TIN is flat (not
>> >> producing a
>> >> 3D file?
>> >> is welcome!
>> >> Yours
>> >> stefania merlo
>> >> UK
>> > Hi Stefania,
>> > Markus
>> > _______________________________________________
> _________________
_________________
