is there a feasible approach in GRASS 6.X or 7.X to apply a 3d vector surface as a cutting pane to split 3D raster volume bodies ?
Best,
Peter
<peter.loewe@gmx.de>
Best,
Peter
On Mon, Oct 7, 2013 at 9:41 PM, "Peter Löwe" <peter.loewe@gmx.de> wrote:
Maybe by using
v.to.rast with use=z (use z coordinate), then followed by
r3.cross.rast (creates cross section 2D raster map from 3D raster map
based on 2D elevation map)
Best
Hi Peter,
you can use v.to.rast to create a raster surface from the vector
surface (as Maskus suggested) and then use r.to.rast3elev to fill the
upper volume and the lower volume of a new voxel map with different
values (upper = 1, lower = 2). Then use r3.mapcalc to perform
operations on the upper or lower volume (r3.mapcalc "lower_volume =
if(myvolume == 2, 1, null())").
Best regards
Soeren
2013/10/7 "Peter Löwe" <peter.loewe@gmx.de>:
is there a feasible approach in GRASS 6.X or 7.X to apply a 3d vector surface as a cutting pane to split 3D raster volume bodies ?Best,
Peter<peter.loewe@gmx.de>
grass-user mailing list
grass-user@lists.osgeo.org
