Yesteday I upgraded my Ubuntu Feisty to the Gutsy Gibbon. When I compiled the last cvs, I could not start the GIS manageger, opened the Outputs windows and stayed hanging. Did somebody else recognize this behavior and/or solved the problem?
the hangup occurs when I select the mapset from the list, only the
Outputs window is opened and then it's hanging. I tried also older cvs
packages, it's the same.
I don't know whether is it a clue, but during the Ubuntu upgrade I lost
somwhere the gdal-config file, so I recompiled the GDAL (version 1.4.0).
After that I compiled the GRASS 6.3 CVS, using this script for the
configure:
Here are some of my problems with gdal-issues compiling GRASS 6.3 from cvs:
I ran into problems after I compiled 6.3. I couldn't start GRASS, it
always crashed of missing libgdal.XXX.so1 (in that manner you described)
After creating symlink to the existing libgdal.1.3.2.so.1, it all whent
fine.
Did the problem occur, when you use the --with-gdal option when you run
./configure
--with-gdal=/usr/bin/gdal-config
Maybe you have to add the libs to your /etc/ld.so.conf. Is there an
entry like /usr/lib?
If not, add it and run sudo ld.config.
As I said, these are the traps where I've been caught by compiling GRASS
from source. Hope one of these helps
Malte
Tomas Lanczos schrieb:
Hi Maris,
configure:
yesss that was it, works now! I had a feeling that I missed something after the Ubuntu upgrade ... thanks for the recall, I appreciate it, very much :-).
Many thanks for everybody who gave advices, grass is a great thing, as well as the whole community around it :-D.
regards
Tomas
Malte Halbey-Martin wrote:
Hi Tomas,
fine.
./configure
Malte
Hi Maris,
configure:
