[GRASS-user] 6.3 v.distance description faulty / ll degrees not meters
Hi!
I've installed grass 6.3, since in the descritption of v.distance
says "In lat-long locations v.distance gives distances (dist and
to_along) in meters not in degrees calculated as geodesic distances
on a sphere.".
I tried it out, but the values produced in a ll location are degrees!
I've checked the source code
(https://svn.osgeo.org/grass/grass/branches/releasebranch_6_3/vector/v.distance/)
and indeed it does not contain any source to compute meters, like
for example in the source for version 6.4.
So, am I correct, that the description is faulty for the 6.3
version, or am I missing something fundamental??
In the first case, could someone correct the desciption, since
it can cause somewhat loss of time and effort (like for me), if one
believes the current description...
Ed.
on a sphere.".
I can confirm 'dist' units are indeed given in decimal degrees in a
Lat/Long location in 6.4.
Devs, what is the intended behavior of the module? If this behavior
is a bug, would it be a simple fix? Otherwise, I'll modify the
docs to mention reported units in degrees.
~ Eric.
2008/8/14 Patton, Eric <epatton@nrcan.gc.ca>:
on a sphere.".
do you mean 6.3?
From r29568 [1] is distance (in LL locations) given in meters. Manual
pages in 6.3 should be fixed.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
2008/8/14 Martin Landa <landa.martin@gmail.com>:
sorry, I forgot the link
http://trac.osgeo.org/grass/changeset/29568
Martin
do you mean 6.3?
No, I meant 6.4, but checking 6.3.1.svn, 'dist' units are decimal
degrees as well.
Sorry, I'm a little confused; from the changeset, it appears that v.distance
was being corrected to able to report in meters, as lat and lon are not
equally scaled. So it seems that a bug in v.distance still exists, then?
Shouldn't r29568 have fixed this?
~ Eric.
do you mean 6.3?
degrees as well.
no, in 6.4 you get distance in meters not decimal degrees. Just
computation is too slow.
Sorry, in which sense? In LL projection is used
Vect_line_geodesic_length() to calculate distances.
Martin
