[GRASS-user] 6.5: Build Error
   Not sure where to report this so I'll do so here.
   Building 6.5 failed with an error in gui/wxpython/vdigit. Per the
instructions, I cd'd to that directory and re-ran make with the attached
results (812 lines).
Rich
(attachments)
error.log.gz (4.8 KB)
Rich
Hi!
On which OS? I think I have seen similar error(s) lately under Ubuntu
Karmic 64-bit.
Nikos
2009/11/17 Rich Shepard <rshepard@appl-ecosys.com>:
pseudodc.cpp:17:34: error: wx/wxPython/wxPython.h: No such file or directory
install wxheaders, eg. on Debian GNU/Linux
apt-get install wx2.8-headers
See gui/wxpython/README for more info.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Karmic 64-bit.
Nikos,
   Slackware-12.2 (32-bit version).
   Linux salmo 2.6.27.7-smp #1 SMP Thu Nov 20 22:18:02 CST 2008 i686 AMD
Athlon(tm) 64 X2 Dual Core Processor 4800+ AuthenticAMD GNU/Linux.
Rich
Martin,
   Slackware does not separate headers from the rest of the code. I built
wxPython-2.8.10 here with the SlackBuild script. Just untarred the source
and there's no wxPython.h in ../src/include/. How interesting.
Rich
what
wx-config --cppflags
says?
Martin
what
says?
Martin,
[rshepard@salmo ~]$ wx-config --cppflags
-I/usr/lib/wx/include/gtk2-unicode-release-2.8 -I/usr/include/wx-2.8
-D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXGTK__
Rich
then
should be located in `/usr/include/wx-2.8`.
Martin
then
Martin,
   Perhaps so, but there's no such header file on this system:
[rshepard@salmo ~]$ locate wxPython.h
[rshepard@salmo ~]$
   This hasn't affected any other application, including my approximate
reasoning model written in Python with wxPython for the GUI.
Rich
then
Can you check what contains this dir?
Martin
Martin,
   Certainly!
[rshepard@salmo ~]$ ls /usr/include/wx-2.8/
wx/
[rshepard@salmo ~]$ ls /usr/include/wx-2.8/wx
aboutdlg.h dcclient.h glcanvas.h msgout.h stopwatch.h
accel.h dcgraph.h graphics.h mstream.h strconv.h
access.h dcmemory.h grid.h notebook.h stream.h
afterstd.h dcmirror.h gsocket.h numdlg.h string.h
anidecod.h dcprint.h gtk/ object.h sysopt.h
animate.h dcps.h hash.h odcombo.h tab.h
animdecod.h dcscreen.h hashmap.h overlay.h tabctrl.h
app.h dde.h hashset.h ownerdrw.h tarstrm.h
apptrait.h debug.h help.h palette.h taskbar.h
archive.h debugrpt.h helpbase.h panel.h tbarbase.h
arrimpl.cpp defs.h helphtml.h paper.h textbuf.h
arrstr.h dialog.h helpwin.h pen.h textctrl.h
artprov.h dialup.h html/ pickerbase.h textdlg.h
aui/ dir.h htmllbox.h platform.h textfile.h
beforestd.h dirctrl.h hyperlink.h platinfo.h tglbtn.h
bitmap.h dirdlg.h icon.h popupwin.h thread.h
bmpbuttn.h display.h iconbndl.h power.h thrimpl.cpp
bmpcbox.h display_impl.h iconloc.h print.h timer.h
bookctrl.h dlimpexp.h imagbmp.h printdlg.h tipdlg.h
brush.h dnd.h image.h prntbase.h tipwin.h
buffer.h docmdi.h imaggif.h process.h tokenzr.h
build.h docview.h imagiff.h progdlg.h toolbar.h
busyinfo.h dragimag.h imagjpeg.h propdlg.h toolbook.h
button.h dynarray.h imaglist.h protocol/ tooltip.h
calctrl.h dynlib.h imagpcx.h ptr_scpd.h toplevel.h
caret.h dynload.h imagpng.h quantize.h treebase.h
checkbox.h effects.h imagpnm.h radiobox.h treebook.h
checklst.h encconv.h imagtga.h radiobut.h treectrl.h
chkconf.h encinfo.h imagtiff.h rawbmp.h txtstrm.h
choicdlg.h event.h imagxpm.h recguard.h types.h
choice.h evtloop.h init.h regex.h unix/
choicebk.h except.h intl.h region.h uri.h
clipbrd.h fdrepdlg.h iosfwrap.h renderer.h url.h
clntdata.h features.h ioswrap.h richtext/ utils.h
clrpicker.h ffile.h ipc.h sashwin.h valgen.h
cmdline.h file.h ipcbase.h sckaddr.h validate.h
cmdproc.h fileconf.h isql.h sckipc.h valtext.h
cmndata.h filedlg.h isqlext.h sckstrm.h variant.h
collpane.h filefn.h joystick.h scopeguard.h vector.h
colordlg.h filename.h layout.h scrolbar.h version.h
colour.h filepicker.h laywin.h scrolwin.h vidmode.h
combo.h filesys.h link.h selstore.h vlbox.h
combobox.h fmappriv.h list.h settings.h vms_x_fix.h
confbase.h font.h listbase.h sizer.h volume.h
config.h fontdlg.h listbook.h slider.h vscroll.h
containr.h fontenc.h listbox.h snglinst.h wave.h
control.h fontenum.h listctrl.h socket.h wfstream.h
convauto.h fontmap.h listimpl.cpp sound.h window.h
cpp.h fontpicker.h log.h spinbutt.h wizard.h
cshelp.h fontutil.h longlong.h spinctrl.h wupdlock.h
ctrlsub.h frame.h math.h splash.h wx.h
cursor.h fs_arc.h matrix.h splitter.h wxPython/
dataobj.h fs_filter.h mdi.h srchctrl.h wxchar.h
dataview.h fs_inet.h mediactrl.h sstream.h wxhtml.h
datectrl.h fs_mem.h memconf.h stack.h wxprec.h
dateevt.h fs_zip.h memory.h stackwalk.h xml/
datetime.h gauge.h memtext.h statbmp.h xpmdecod.h
datstrm.h gbsizer.h menu.h statbox.h xpmhand.h
db.h gdicmn.h menuitem.h statline.h xrc/
dbgrid.h gdiobj.h metafile.h stattext.h xti.h
dbkeyg.h generic/ mimetype.h statusbr.h xtistrm.h
dbtable.h geometry.h minifram.h stc/ xtixml.h
dc.h gifdecod.h module.h stdpaths.h zipstrm.h
dcbuffer.h gizmos/ msgdlg.h stockitem.h zstream.h
[rshepard@salmo ~]$ ls /usr/include/wx-2.8/wx/wxPython/
i_files/
[rshepard@salmo ~]$ ls /usr/include/wx-2.8/wx/wxPython/i_files/
_richtextbuffer.i _richtextctrl.i _richtexthtml.i _richtextxml.i
Rich
Certainly!
wx/
no new info - wxPython headers are missing (only wxWidgets are
included) - you need to install them...
Martin
Martin,
   Certainly!
i_files/
Oops. I have:
  $ ls -1F /usr/include/wx-2.8/wx/wxPython/
  i_files/
  printfw.h
  pseudodc.h
  pyclasses.h
  pydrawxxx.h
  pyistream.h
  pytree.h
  swigver.h
  twoitem.h
  wxPython.h
  wxPython_int.h
It looks like Slackware's wxPython package is incomplete.
no new info - wxPython headers are missing (only wxWidgets are included) -
Martin,
   They're not in the source code.
Rich
On Tue, 17 Nov 2009, Glynn Clements wrote:
Oops. I have:
  i_files/
  printfw.h
  pseudodc.h
  pyclasses.h
  pydrawxxx.h
  pyistream.h
  pytree.h
  swigver.h
  twoitem.h
  wxPython.h
  wxPython_int.h
Glynn,
   When I dug deeper in the source I found those and copied them over.
   I don't know how the script could miss this, but I'll report it to the
maintainer.
Thanks ... and thanks to Martin, too,
Rich
   Oops! Yes it is. Just hidden deeply.
Rich
Martin,
Silly question: if you compiled wxPython from source yourself with make; make install, did you also
cd $WXDIR/wxPython
python setup.py install
as described in $WXDIR/wxPython/docs/INSTALL.txt ?
Or check the SlackBuild script you used if it's doing that.
Markus M
Markus,
   Yes, it does.
Rich
