[GRASS-user] 6.5svn Build Problem
   I've not before had 6.5svn throw an error when building. After updating to
the latest modules in the repository I configured and built the application.
There was a build error in ../gui/wxpython so I cd'd to that subdirectory
and ran make. From the base directory I ran 'make install', then tried
invoking GRASS only to see this error:
Cleaning up temporary files ...
Starting GRASS ...
ERROR: wxGUI requires wxPython. No module named wxversion
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
   wxPython-2.8.12.1 is installed. But, indeed, there is nothing named
'wxversion' on this system. The -6.5svn source tree shows attempts to import
wxversion in:
grass6_devel/gui/wxpython/core/globalvar.py: import wxversion
grass6_devel/gui/wxpython/core/globalvar.py: #
wxversion.select(str(minVersion[0]) + '.' + str(minVersion[1]))
wxversion.ensureMinimal(str(minVersion[0]) + '.' + str(minVersion[1]))
grass6_devel/gui/wxpython/core/globalvar.py: except (ValueError,
wxversion.VersionError), e:
grass6_devel/gui/wxpython/README: lib64wxPythonGTK2.8
lib64wxPythonGTK2.8-devel wxPythonGTK wxPythonGTK-wxversion
grass6_devel/.svn/pristine/1b/1b81bbe95f076b38a9707473beb875f3eebde6f5.svn-base:
lib64wxPythonGTK2.8 lib64wxPythonGTK2.8-devel wxPythonGTK
grass6_devel/.svn/pristine/f1/f1efdd5e9fed65bd04ef8cd00ef8471c93502320.svn-base:
import wxversion
# wxversion.select(str(minVersion[0]) + '.' + str(minVersion[1]))
# wxversion.ensureMinimal(str(minVersion[0]) + '.' + str(minVersion[1]))
# except (ValueError, wxversion.VersionError), e:
gui/wxpython/core/globalvar.py: # wxversion.select(str(minVersion[0])
gui/wxpython/README: lib64wxPythonGTK2.8 lib64wxPythonGTK2.8-devel
   Where do you suggest I start looking for the source of this error?
Rich
Richard B. Shepard, Ph.D. | Have knowledge, will travel.
Applied Ecosystem Services, Inc. |
www.appl-ecosys.com Voice: 503-667-4517 Fax: 503-667-8863
import
wxversion in:
install wxversion on your system?
why not using the upcoming stable release GRASS7
GRASS GIS 7.0.0beta1 released
http://lists.osgeo.org/pipermail/grass-user/2014-March/070056.html
a lot of new stuff (e.g. r.stream.* included, ...), already pretty stable,
AFAIK also there wxversion is needed.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/6-5svn-Build-Problem-tp5131692p5131892.html
Helmut,
   I thought that wxversion was included in wxPython, which is installed
here.
   Because it will not build; the make effort produces multiple errors in the
../gui/wxpython/ subdirectories.
   All this with wxPython-2.8.12.1 installed.
Rich
On Fri, Mar 28, 2014 at 12:03 PM, Rich Shepard <rshepard@appl-ecosys.com>wrote:
Helmut,
here.
wxversion is a usually a separate package. The reason is that it access
all the other versions.
the
The 6.5 is not working for you either, so I would try GRASS 7 (beta)
again. Moreover, recently there was a change which might improve the build
in gui/wxpython/ subdirectories. Also note that if the build fails there,
it does not necessary mean that tit will not work at all (it just behave
strangely sometimes).
Which system are you using anyway?
Vaclav
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Vaclav,
   It is quite difficult to find wxpython.py. There's no SlackBuild.org
version and a Web search finds references to using it on wxpython's wiki and
PyPi, but no module source to install. Since I use only one version of
wxPython here is there a --disable option in the configuration to eliminate
it?
build in gui/wxpython/ subdirectories. Also note that if the build fails
there, it does not necessary mean that tit will not work at all (it just
behave strangely sometimes).
   Until yesterday 6.5 built without error for several years. GRASS-7.0 keeps
failing to build, probably because there's no wxversion here.
   Slackware-14.1.
Rich
and PyPi, but no module source to install.
   Anyway, I removed the wxPython-2.8.12.1 SlackBuild package, built and
installed (I believe), wxPython-3.0.0.0.
   In /usr/lib/python2.7/site-packages/wx-3.0-gtk2/wx/py/ is version.py and
version.pyc.
   Now my question is: How do I pass this path to the GRASS configuration so
it can find version.py?
Rich
   OK, wxPython-3.0.0.0 installed and version.py is present. So, ...
   From the main grass-6.5svn/ directory's error.log:
GRASS GIS compilation log
Started compilation: Fri Mar 28 14:34:50 PDT 2014
Errors in:
/home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Fri Mar 28 14:44:19 PDT 2014
    In ../gui/wxpython/ I run 'make' and see this output:
make parsubdirs
make[1]: Entering directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython'
make -C docs || echo /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs >> /home/rshepard/GIS/GRASS/grass-6.5svn/error.log
make[2]: Entering directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs'
for file in wxGUI wxGUI.PsMap wxGUI.Vector_Digitizer wxGUI.Components wxGUI.Modeler wxGUI.GCP_Manager wxGUI.Nviz wxGUI.Attribute_Table_Manager ; do \
      rm -f $file.tmp.html ; \
      rm -f "/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/$file.html"; \
      make htmldir PGM=$file; \
done
make[3]: Entering directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs'
make /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.html
make[4]: Entering directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs'
if [ "" != "" ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
make[4]: Leaving directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs'
make[3]: Leaving directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs'
make /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.PsMap.html
if [ "" != "" ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.PsMap.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI.PsMap ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.PsMap.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.PsMap.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
make /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Vector_Digitizer.html
if [ "" != "" ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.Vector_Digitizer.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI.Vector_Digitizer ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.Vector_Digitizer.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Vector_Digitizer.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
make /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Components.html
if [ "" != "" ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.Components.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI.Components ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.Components.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Components.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
make /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Modeler.html
if [ "" != "" ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.Modeler.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI.Modeler ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.Modeler.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Modeler.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
make /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.GCP_Manager.html
if [ "" != "" ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.GCP_Manager.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI.GCP_Manager ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.GCP_Manager.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.GCP_Manager.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
make /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Nviz.html
if [ "" != "" ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.Nviz.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI.Nviz ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.Nviz.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Nviz.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
make /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Attribute_Table_Manager.html
if [ "" != "" ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:" LC_ALL=C --html-description < /dev/null | grep -v '</body>\|</html>' > wxGUI.Attribute_Table_Manager.tmp.html ; true ; fi
../../../tools/mkhtml.sh wxGUI.Attribute_Table_Manager ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.Attribute_Table_Manager.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Attribute_Table_Manager.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
/home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs' make[3]: Leaving
directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs' make[2]:
make[1]: Leaving directory
    Then, as root, I 'make install'. But, when I start GRASS I see:
[rshepard@salmo ~/GIS/GRASS/grass-6.5svn]$ grass65 Cleaning up temporary files ...
Starting GRASS ...
ERROR: wxGUI requires wxPython. libwx_gtk2u_xrc-3.0.so.0: cannot open shared
object file: No such file or directory
Switching to text mode now.
Hit RETURN to continue...
    Does this provide more detailed information that might lead one of you
developers to figure out where the problem is?
Thanks in advance,
Rich
On Fri, Mar 28, 2014 at 6:03 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
I’ve not before had 6.5svn throw an error when building.
OK, wxPython-3.0.0.0 installed and version.py is present. So, …
could you just try importing wxpython in python console outside of grass session:
import wxversion
import wx
to make sure it’s working? (Sorry if you already did that)
Anna
From the main grass-6.5svn/ directory’s error.log:
Errors in:
In case of errors please change into the directory with error and run ‘make’.
In …/gui/wxpython/ I run ‘make’ and see this output:
make parsubdirs
make[1]: Entering directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython’
make[2]: Entering directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs’
rm -f “/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/$file.html”;
done
make[3]: Entering directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs’
make[4]: Entering directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs’
if [ “” != “” ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH=“/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH” LD_LIBRARY_PATH=“/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:” LC_ALL=C --html-description < /dev/null | grep -v ‘|’ > wxGUI.tmp.html ; true ; fi
…/…/…/tools/mkhtml.sh wxGUI ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.html ; for file in *.png *.jpg ; do head -n 1 $file | grep ‘^#!’ > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
make[4]: Leaving directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs’
make[3]: Leaving directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs’
if [ “” != “” ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH=“/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH” LD_LIBRARY_PATH=“/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:” LC_ALL=C --html-description < /dev/null | grep -v ‘|’ > wxGUI.PsMap.tmp.html ; true ; fi
…/…/…/tools/mkhtml.sh wxGUI.PsMap ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.PsMap.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.PsMap.html ; for file in *.png *.jpg ; do head -n 1 $file | grep ‘^#!’ > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
if [ “” != “” ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH=“/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH” LD_LIBRARY_PATH=“/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:” LC_ALL=C --html-description < /dev/null | grep -v ‘|’ > wxGUI.Vector_Digitizer.tmp.html ; true ; fi
…/…/…/tools/mkhtml.sh wxGUI.Vector_Digitizer ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.Vector_Digitizer.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Vector_Digitizer.html ; for file in *.png *.jpg ; do head -n 1 $file | grep ‘^#!’ > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
if [ “” != “” ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH=“/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH” LD_LIBRARY_PATH=“/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:” LC_ALL=C --html-description < /dev/null | grep -v ‘|’ > wxGUI.Components.tmp.html ; true ; fi
…/…/…/tools/mkhtml.sh wxGUI.Components ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.Components.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Components.html ; for file in *.png *.jpg ; do head -n 1 $file | grep ‘^#!’ > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
if [ “” != “” ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH=“/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH” LD_LIBRARY_PATH=“/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:” LC_ALL=C --html-description < /dev/null | grep -v ‘|’ > wxGUI.Modeler.tmp.html ; true ; fi
…/…/…/tools/mkhtml.sh wxGUI.Modeler ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.Modeler.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Modeler.html ; for file in *.png *.jpg ; do head -n 1 $file | grep ‘^#!’ > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
if [ “” != “” ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH=“/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH” LD_LIBRARY_PATH=“/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:” LC_ALL=C --html-description < /dev/null | grep -v ‘|’ > wxGUI.GCP_Manager.tmp.html ; true ; fi
…/…/…/tools/mkhtml.sh wxGUI.GCP_Manager ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.GCP_Manager.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.GCP_Manager.html ; for file in *.png *.jpg ; do head -n 1 $file | grep ‘^#!’ > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
if [ “” != “” ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH=“/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH” LD_LIBRARY_PATH=“/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:” LC_ALL=C --html-description < /dev/null | grep -v ‘|’ > wxGUI.Nviz.tmp.html ; true ; fi
…/…/…/tools/mkhtml.sh wxGUI.Nviz ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.Nviz.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Nviz.html ; for file in *.png *.jpg ; do head -n 1 $file | grep ‘^#!’ > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
if [ “” != “” ] ; then GISRC=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu PATH=“/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:$PATH” LD_LIBRARY_PATH=“/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/bin:/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/lib:/usr/lib/qt/lib:/usr/lib/qt/lib:” LC_ALL=C --html-description < /dev/null | grep -v ‘|’ > wxGUI.Attribute_Table_Manager.tmp.html ; true ; fi
…/…/…/tools/mkhtml.sh wxGUI.Attribute_Table_Manager ; mkdir -p /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/ginstall -c -m 644 wxGUI.Attribute_Table_Manager.tmp.html /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/wxGUI.Attribute_Table_Manager.html ; for file in *.png *.jpg ; do head -n 1 $file | grep ‘^#!’ > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/ginstall -c -m 644 $file /home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
/home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs’ make[3]: Leaving
directory /home/rshepard/GIS/GRASS/grass-6.5svn/gui/wxpython/docs’ make[2]:
Then, as root, I ‘make install’. But, when I start GRASS I see:
[rshepard@salmo ~/GIS/GRASS/grass-6.5svn]$ grass65 Cleaning up temporary files …
Starting GRASS …
Hit RETURN to continue…
Thanks in advance,
Rich
On Fri, Mar 28, 2014 at 6:49 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
  Slackware-14.1.
Could it be included in
http://repository.slacky.eu/slackware-14.1/libraries/wxGTK/2.8.12/
session:
import wxversion
import wx
to make sure it's working? (Sorry if you already did that)
Anna,
   Sure:
In [1]: import wxversion
In [2]: import wx
In [3]:
   No errors reported.
Rich
Markus, et al.:
   Thanks for the pointer to the problem: I _thought_ I read somewhere that
wxGTK was included in wxPython and that both could not be installed
together. So I removed the installed wxGTK.
   I was wrong. They are both needed.
   I just built and installed wxGTK3 and grass-6.5svn once again builds
without errors. Will now try -7.0.
My apologies to everyone,
Rich
Rich,
glad you solved it.
Let's put a note to the Wiki page about 'Compile and Installation'...
Best
On Sat, 29 Mar 2014, Rich Shepard wrote:
Will now try -7.0.
   Same problem: wxGTK needed in addition to wxPython. Built error-free and
installed.
Rich
