I just ran 'svn up': 14:00 PST Friday 2012-01-27, configured, built, and
installed the latest code. Didn't record the build number.
Within the wxPython GUI I opened a point map and tried to query a point
for information about it. GRASS immediately crashed. The virtual console
shows:
GRASS_INFO_ERROR(1491,1): Unable to open database
</home/rshepard/grassdata/Washington-SPCS/Buckhorn/dbf/>
GRASS_INFO_END(1491,1)
GRASS_INFO_ERROR(1494,1): Unable to describe table
<Buckhorn_Surface_Water_Stations>
GRASS_INFO_END(1494,1)
dbmi: Protocol error
GRASS_INFO_ERROR(1516,1): Unable to open database
GRASS_INFO_END(1516,1)
GRASS_INFO_ERROR(1519,1): Unable to describe table
GRASS_INFO_END(1519,1)
I had imported this map from a shapefile a few weeks ago but had not
looked at it before now. Where do I start looking for the problem with
opening the GRASS database?
Just tried to re-import the file. Command window shows:
(Fri Jan 27 14:44:02 2012) v.in.ogr dsn=/home/rshepard/projects/washington/buckhorn/spatial/Buckhorn_Surface_Water_Stations.shp layer=Buckhorn_Surface_Water_Stations output=Buckhorn_Surface_Water_Stations --overwrite -e -w
Vector map <Buckhorn_Surface_Water_Stations> already exists and will be overwritten
Projection of input dataset and current location appear to match
Unable to open database </home/rshepard/grassdata/Washington-SPCS/Buckhorn/dbf/> by driver <dbf>
Unable open database </home/rshepard/grassdata/Washington-SPCS/Buckhorn/dbf/> by driver <dbf>
Unable to find table <Buckhorn_Surface_Water_Stations> linked to vector map <Buckhorn_Surface_Water_Stations>
ERROR: Unable to delete vector map <Buckhorn_Surface_Water_Stations>
(Fri Jan 27 14:44:03 2012) Command finished (0 sec)
virtual console
shows:
It didn't like a change to db__recv_procnum() in
lib/db/dbmi_base/xdrprocedure.c
made 2 hours ago.
it's now back to the old (working) way in devbr6,
