The directory biota/ contains the subdirectory bulltrout/, which contains
two files and two subdirectories: VAR WIND dbf/ vector/. The map is named
bulltrout2008.
As this mapset became disconnected from the location in which it was
originally imported I want to learn how to turn it into a location or
otherwise access it to reproject the bulltrout2008 map to a different
projection.
If there's a module for this I've missed seeing it.
TIA,
Rich
Hello Rich,
Create a new directory and copy & rename biota to PERMANENT in this folder. Copy PERMANENT/WIND to PERMANENT/DEFAULT_WIND. Now this folder is a new location with the biota data as a PERMANENT mapset.
Best,
Huidae
On Fri, Jun 29, 2018 at 5:19 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
bulltrout2008.
projection.
If there’s a module for this I’ve missed seeing it.
TIA,
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Huidae Cho, Ph.D., PE, M.ASCE, CFM, GISP
Senior Geospatial Engineer, MapAnything
Open Source GIS Developer, GRASS GIS Development Team
Huidae,
Thank you for another complete answer.
Much appreciated,
Rich
