Something must have changed in the subversion repository and I want to
confirm that this is a deliberate change.
At least once a week when I'm working with grass I start by checking for
upgrades using 'svn up'. The past month or two the server's response is that
I'm already at the current revision, just now that's at revision 72862. I'm
having trouble understanding how upgrades are being pushed to me without my
knowledge or active requests.
On Wed, Jun 20, 2018 at 11:41 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
... nothing was changed. The server operates as before.
As of now, i.e. date -u
Thu Jun 21 20:49:37 UTC 2018
This morning I checked out the trunk, configured and built it. This told
me the revision number is 72869. I assume that's the most current revision
as it's the at the bottom of that web page dated Thu Jun 21 13:57:47 PDT
2018.
for svn related command options, the easiest thing is to consult the svn
manual.
As a non-developer who does not commit changes I use either co or up.
Usually the latter. The other commands are not appropriate for me.
Neither of these explain why 'svn up' returns the result that I'm at the
latest revision when no new code has been downloaded.
Please tell us where you exactly see this number.
Markus,
Yesterday morning the revision was 72869 (as above). Just now:
$ svn up
Updating '.':
At revision 72886.
I have not explicitly downloaded anything from the repository since I
checked out and built 72869, so I don't know why svn tells me my local
source is at revision 72886.
I assume that's the most current revision as it's the at the bottom of
that web page dated Thu Jun 21 13:57:47 PDT 2018.
Yes. The "confusion" may arise from the fact that rev numbers are
handled globally across the GRASS GIS SVN repo which also contains
grass-addons, sandbox and more.
Any change leads to an increment of the revision number. The last
changes happened in grass-addons, pushing the rev number to currently
revision 72887. However, that does not necessarily mean that trunk
received an update.
$ svn up
Updating '.':
At revision 72886.
Markus,
My response to your clarification was mis-handled (by me) and not sent.
Now I understand that when 'svn up' does not download any files it's because
the source here is at the latest _trunk_ revision. I should have looked more
closely at the checkin log web page.
