[GRASS-user] 7.9.dev build issue
Trying to build 7.9.dev today failed:
checking whether to use libLAS... yes
checking for liblas-config... /usr/bin/liblas-config
checking for liblas/capi/liblas.h... yes
configure: error: *** Unable to locate libLAS library.
libLAS-1.8.1 is installed; liblas libraries installed are:
/usr/lib64/liblastfm_fingerprint.so.1.0.9
/usr/lib64/liblaszip.la
/usr/lib64/liblas.so.2.4.0
/usr/lib64/liblas_c.so.3
/usr/lib64/liblaszip.so.6.0.0
/usr/lib64/liblastfm.so
/usr/lib64/liblas_c.so.2.4.0
/usr/lib64/liblastfm.so.1.0.9
/usr/lib64/liblas.so.3
A pointer on what I've missed will be appreciated.
Rich
Rich Shepard <rshepard@appl-ecosys.com> schrieb am Di., 12. Nov. 2019, 19:16:
checking whether to use libLAS… yes
checking for liblas-config… /usr/bin/liblas-config
checking for liblas/capi/liblas.h… yes
A pointer on what I’ve missed will be appreciated.
Please check config.log for details.
Regards
grass-user mailing list
grass-user@lists.osgeo.org
On Tue, 12 Nov 2019, Markus Neteler wrote:
Please check `config.log` for details.
Markus,
I should have attached that to my message.
I think that I see the error:
configure:7009: gcc -o conftest -g -O2 -O2 -fPIC -I/usr/include -I/usr/include -I/usr/include -I/usr/include -I/usr/include -Wl,--export-dynamic -L/usr/lib64 conftest.c -L/usr/lib -llas -llas_c -L/usr/lib64 /usr/lib64/libboost_program_options.so /usr/lib64/libboost_thread.so /usr/lib64/libgdal.so /usr/lib64/libgeotiff.so /usr/lib64/libtiff.so /usr/lib64/liblaszip.so 1>&5
/usr/lib64/gcc/x86_64-slackware-linux/5.5.0/../../../../x86_64-slackware-linux/bin/ld: warning: libgdal.so.20, needed by /usr/lib64/liblas.so, not found (try using -rpath or -rpath-link)
/usr/lib64/gcc/x86_64-slackware-linux/5.5.0/../../../../x86_64-slackware-linux/bin/ld: warning: libproj.so.13, needed by /usr/lib64/libgeotiff.so, not found (try using -rpath or -rpath-link)
/usr/lib64/liblas.so: undefined reference to `OGRSpatialReference::FixupOrdering()'
collect2: error: ld returned 1 exit status
This morning I upgraded to proj-6.2.1-x86_64-1_SBo, geos-3.8.0-x86_64-1_SBo,
and gdal-3.0.2-x86_64-1_SBo. And libLAS-1.8.1-x86_64-1_SBo is also
installed, but fails to rebuild.
Reading the liblas.org web page I think I should remove the liblas package
then build and install the pdal-1.9.1 package. Is this a good idea?
Rich
Built and install pdal-1.9.1. In the configuration file I commented out
--with-libLAS and added --with-pdal. Grass didn't recognize the latter.
Without libLAS grass built with no errors.
How best to specify including pdal?
Rich
Rich,
On Tue, Nov 12, 2019 at 8:11 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
Markus,
^-- libgdal.so.20 not found
However, since you use GDAL 3, the same is "libgdal.so.26".
(see https://github.com/OSGeo/grass/pull/191/files)
Means, that liblas needs to be recompiled against the (new) GDAL
installation on your machine.
^-- libproj.so.13 not found
The same here: libgeotiff needs to be recompiled against the updated PROJ.
Yes, it is important to recompile in the right order to keep up with
the dependency tree
(unless you install packages from the distro where these dependencies
have been respected in the respective compile scripts).
HTH,
Markus,
I could make a new softlink.
That's what I tried to do, but liblas failed to build.
I recompiled libgeotiff but libgeospatialite failed to build; I've asked on
that mail list for help.
Yes, it is important to recompile in the right order to keep up with the
dependency tree (unless you install packages from the distro where these
dependencies have been respected in the respective compile scripts).
Slackware doesn't automatically build dependencies nor build packages in a
defined sequence. Such tasks are left to the user and after many years I'm
well used to it.
Question: Yesterday I read that liblas has been deprecated in favor of pdal
and I have a vague recollection of reading (a mail message? a web page?)
that GRASS was accommodating this change. So I stopped trying to build
liblas, built and installed pdal, but could not get grass to incorporate it.
Will this transition be made reasonably soon?
Rich
On Wed, Nov 13, 2019 at 2:47 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
Markus,
This will not work (or show hidden errors) as they are likely not
version compatible (GDAL 2 vs GDAL 3).
Yes, if the softlink was in place then it is expected.
(see above)
well used to it.
ok, so you need to compile probably in this order:
- proj
- geotiff
- (other GDAL dependencies)
- gdal
- liblas (maybe outdated)
- pdal
- grass
There is an open pull request for GRASS core:
"r.in.pdal - PDAL-based version of r.in.lidar"
https://github.com/OSGeo/grass/pull/61
As a workaround, there is an addon:
https://grass.osgeo.org/grass7/manuals/addons/r.in.pdal.html
which just requires the PDAL binary to be running.
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://courses.neteler.org/blog
"Could" is the meaningful word. I did not do this.
See above.
- proj
- geotiff
- gdal
- pdal
- grass
I've always used proj -> geos -> gdal then other libraries. libLAS won't
build here.
I don't need either liblas or pdal now; not currently working with LiDAR
data.
Rich
