A couple of weeks ago I pulled changed files from the 7.9.dev github repo
and the new source configured, built, and installed with no errors.
Today it cannot find pdal-config (which is in /usr/bin/pdal-config along
with /usr/bin/pdal and /usr/include/pdal/ because pdal-2.2.0 is installed
here:
checking whether to use PDAL... yes
checking for pdal-config... /usr/bin/pdal-config
configure: error: *** Unable to locate PDAL library.
I'd like suggestions where to look for the problem.
As there is no problem with pdal 2.1.0, it could be that something has
changed in pdal. Please take a look into config.log file to see the
actual error. If there isn't something that looks like a problem
specific to your machine, open a bug report and attach failing part of
config.log.
here:
changed in pdal. Please take a look into config.log file to see the actual
error. If there isn't something that looks like a problem specific to your
machine, open a bug report and attach failing part of config.log.
Maris.
I should have looked there first.
The error is "libgdal.so.26, needed by /usr/lib64/libpdal_base.so, not
found". That's because Slackware upgraded gdal so libgdal.so.28 is
installed. I thought that grass would find and use the newer gdal-3.2.2
that's installed.
I don't remember how to tell grass-7.9.dev there's a new version of gdal
installed.
Thank you very much. I completely missed that. I've known for a while that I
need to recompile the stack proj -> geos -> gdal when proj or geos is
upgraded but I didn't realize that I need to add pdal to the end of this
chain. Now I know.
