[GRASS-user] 7.9.dev: which wxPython versions supprted?
From neteler@osgeo.org Mon May 25 14:35:42 2020
Rich,
did you see
https://github.com/OSGeo/grass/issues/649
To which I responded,
Nope. I'll grab wxPython-4.1.0 and see if it builds with the SBo script.
Here's the latest;
I'm moving this to the user mail list because I'm not subscribed to the dev
mail list.
I downloaded wxPython-7.1.0 source code, changed the version number in the
SlackBuilds.org (SBo) build script, and the build completed without errors
other than a couple of empty metadata files.
However, when I try to start 'grass79 -gui' it fails with these errors:
$ grass79 -gui
Starting GRASS GIS...
(gis_set.py:20526): Gtk-WARNING **: Theme parsing error: <data>:1:96: 'caret-color' is not a valid property name
(gis_set.py:20526): Gtk-WARNING **: Theme parsing error: <data>:1:97: 'caret-color' is not a valid property name
(gis_set.py:20526): Gtk-WARNING **: Theme parsing error: <data>:1:94: 'caret-color' is not a valid property name
(gis_set.py:20526): Gtk-WARNING **: Theme parsing error: <data>:1:122: 'caret-color' is not a valid property name
(gis_set.py:20526): Gtk-WARNING **: Theme parsing error: <data>:1:135: 'caret-color' is not a valid property name
   File "/usr/local/grass79/gui/wxpython/gis_set.py", line 1148, in OnInit
     StartUp = GRASSStartup()
   File "/usr/local/grass79/gui/wxpython/gis_set.py", line 224, in __init__
     self._do_layout()
   File "/usr/local/grass79/gui/wxpython/gis_set.py", line 399, in _do_layout
     description=self.llocation)
   File "/usr/local/grass79/gui/wxpython/gis_set.py", line 376, in layout_list_box
     border=1)
wx._core.wxAssertionError: C++ assertion "!(flags & wxALIGN_CENTRE_HORIZONTAL)" failed at /tmp/SBo/wxPython-4.1.0/ext/wxWidgets/src/common/sizer.cpp(2106) in DoInsert(): Horizontal alignment flags are ignored in horizontal sizers
OnInit returned false, exiting...
ERROR: Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.
To run GRASS GIS in text mode use the --text flag.
Use '--help' for further options
      grass79 --help
See also: https://grass.osgeo.org/grass79/manuals/helptext.html
Exiting...
Is this a grass issue or an SBo issue? If the latter I'll let the package
maintainer know and he'll probably have it fixed tomorrow.
Rich
tl;dr Only master branch (7.9) has some wxPython-4.1 related fixes.
Unless you are ready to provide fixes, do not mix GRASS with wxPython
4.0.
Māris.
On Tue, 26 May 2020, Maris Nartiss wrote:
tl;dr Only master branch (7.9) has some wxPython-4.1 related fixes. Unless
4.0.
Māris,
I'm not sure that I'm following you. I'm building (and using) 7.9.dev, the
master branch, as indicated in the subject. There were issues with 4.0.6
that are supposed to be fixed in 4.1.0 which is why I upgraded.
Rich
