[GRASS-user] 8 Release Candidate
I’ve been trying to run the 8 release candidate. I’m on a stock Ubuntu (21.10) install and I’ve downloaded the binary 8 release candidate for grass. I do have Grass 7.8.5 running.
Anyway - I’ve installed in a custom location and in the default. I start grass and get. The GRASS Splash screen does come up and stays up for about 2 secs and then I’m sitting at the prompt. I can’t get the GUI up and running. Thoughts (I can file a bug report if needed):
./grass
Starting GRASS GIS...
Cleaning up temporary files...
          __________  ___   __________    _______________
         / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
        / / __/ /_/ / /| | \__ \_  \   / / __ / / \__ \
       / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
       \____/_/ |_/_/  |_/____/____/   \____/___//____/
Welcome to GRASS GIS 8.0.0dev (4d15e3313)
GRASS GIS homepage:                      [https://grass.osgeo.org](https://grass.osgeo.org)
This version running through:            Bash Shell (/bin/bash)
Help is available with the command:      g.manual -i
See the licence terms with:              g.version -c
See citation options with:               g.version -x
If required, restart the GUI with:       g.gui wxpython
When ready to quit enter:                exit
Launching <wxpython> GUI in the background, please wait...
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
GRASS world_latlong_wgs84/PERMANENT:bin > Traceback (most recent call last):
  File "/usr/lib/python3/dist-packages/wx/core.py", line 3282, in <lambda>
    lambda event: event.callable(*event.args, **event.kw) )
  File "/home/rjhale/temp/grass/gui/wxpython/wxgui.py", line 86, in show_main_gui
    from lmgr.frame import GMFrame
  File "/home/rjhale/temp/grass/gui/wxpython/lmgr/frame.py", line 45, in <module>
    from gui_core.preferences import MapsetAccess, PreferencesDialog
  File "/home/rjhale/temp/grass/gui/wxpython/gui_core/preferences.py", line 52, in <module>
    from gui_core.dialogs import SymbolDialog, DefaultFontDialog
  File "/home/rjhale/temp/grass/gui/wxpython/gui_core/dialogs.py", line 44, in <module>
    from gui_core.gselect import (
  File "/home/rjhale/temp/grass/gui/wxpython/gui_core/gselect.py", line 62, in <module>
    from grass.lib.imagery import (
  File "/home/rjhale/temp/grass/etc/python/grass/lib/imagery.py", line 30, in <module>
    _libs["grass_imagery.8.0"] = load_library("grass_imagery.8.0")
  File "/home/rjhale/temp/grass/etc/python/grass/lib/ctypes_loader.py", line 89, in __call__
    raise ImportError("Could not load %s." % libname)
ImportError: Could not load grass_imagery.8.0.
Randal Hale
[rjhale@northrivergeographic.com](mailto:rjhale@northrivergeographic.com)
[https://www.northrivergeographic.com](https://www.northrivergeographic.com)
On Sun, Jan 23, 2022 at 9:41 AM Randal Hale <rjhale@northrivergeographic.com> wrote:
./grass
        / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
    lambda event: event.callable(*event.args, **[event.kw](http://event.kw)) )
I just pushed a fix [1], so the GUI should at least start now, but I don’t know why grass can’t load the library. So some functionality still won’t work (e.g. 3D, digitizer).
Anna
[1] https://github.com/OSGeo/grass/pull/2120
Randal Hale
grass-user mailing list
grass-user@lists.osgeo.org
Thanks! Just got back to this - I’ll test it out.
Randy
./grass
Anna
Randal Hale
Randal Hale
